R33 GTR RB26DETT
Complete motor, sump to covers, all intake side and n1 turbos in excellent condition, no accessories.
No pwr steer pump, a/c or flywheel. No coil packs or any loom.
These are available for extra.
R33 crank (long drive oil gear)
Forged CP pistons 86.5mm
Standard Shot Peened Rods
N1 oil pump with billet gears
N1 water pump
ACL Race series Bearings
Tomei oil gallery restrictor
Tomei 1.2mm headgasket
Tomei sump baffle
Kept piston oil squirters
polished plenum
Red wrinkle painted rocker & timing covers, no valley cover
Nissan timing belt/tensioner replaced at build, painted engine block
Completely reco'd head with standard cams valve clearances adjusted
Brand new cam cover seals replaced
Engine has had sump removed, parts inspected, leak down tested, valves vacuum tested and engine compression tested all available for genuine buyers only, photos available for these tests also as well as a video of the car running prior to removal.
Has done 10,000kms since rebuild
$5500 no turbo side or injectors
$6500 with turbos and injectors
Also have clutch Ecu etc for extra
Fitting available for extra
Will freight at buyers expense
Gold Coast
0487924497
Hey mate,
Just wanted clarification on something. In the top section of your ad write up, you have listed N1 turbochargers (in excellent condition) in addition to intake side, for what can be assumed as $5500, according to the title of your thread.
However further down you have listed the price as $5500 without said turbochargers, and $6500 with. The Trust turbochargers don't interest me, but if the N1's are R34-spec, and for $5500, that would be a good buy.
Keen to get some more info.. Thanks in advance.
