R33 GTR RB26DETT
Complete motor, sump to covers, all intake side and n1 turbos in excellent condition, no accessories.
No pwr steer pump, a/c or flywheel. No coil packs or any loom.
These are available for extra.
R33 crank (long drive oil gear)
Forged CP pistons 86.5mm
Standard Shot Peened Rods
N1 oil pump with billet gears
N1 water pump
ACL Race series Bearings
Tomei oil gallery restrictor
Tomei 1.2mm headgasket
Tomei sump baffle
Kept piston oil squirters
polished plenum
Red wrinkle painted rocker & timing covers, no valley cover
Nissan timing belt/tensioner replaced at build, painted engine block
Completely reco'd head with standard cams valve clearances adjusted
Brand new cam cover seals replaced
Engine has had sump removed, parts inspected, leak down tested, valves vacuum tested and engine compression tested all available for genuine buyers only, photos available for these tests also as well as a video of the car running prior to removal.
Has done 10,000kms since rebuild
$5500 no turbo side or injectors
$6500 with turbos and injectors
Also have clutch Ecu etc for extra
Fitting available for extra
Will freight at buyers expense
Gold Coast
0487924497
Hey mate,
Just wanted clarification on something. In the top section of your ad write up, you have listed N1 turbochargers (in excellent condition) in addition to intake side, for what can be assumed as $5500, according to the title of your thread.
However further down you have listed the price as $5500 without said turbochargers, and $6500 with. The Trust turbochargers don't interest me, but if the N1's are R34-spec, and for $5500, that would be a good buy.
Keen to get some more info.. Thanks in advance.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
