R33 GTR RB26DETT
Complete motor, sump to covers, all intake side and n1 turbos in excellent condition, no accessories.
No pwr steer pump, a/c or flywheel. No coil packs or any loom.
These are available for extra.
R33 crank (long drive oil gear)
Forged CP pistons 86.5mm
Standard Shot Peened Rods
N1 oil pump with billet gears
N1 water pump
ACL Race series Bearings
Tomei oil gallery restrictor
Tomei 1.2mm headgasket
Tomei sump baffle
Kept piston oil squirters
polished plenum
Red wrinkle painted rocker & timing covers, no valley cover
Nissan timing belt/tensioner replaced at build, painted engine block
Completely reco'd head with standard cams valve clearances adjusted
Brand new cam cover seals replaced
Engine has had sump removed, parts inspected, leak down tested, valves vacuum tested and engine compression tested all available for genuine buyers only, photos available for these tests also as well as a video of the car running prior to removal.
Has done 10,000kms since rebuild
$5500 no turbo side or injectors
$6500 with turbos and injectors
Also have clutch Ecu etc for extra
Fitting available for extra
Will freight at buyers expense
Gold Coast
0487924497
Hey mate,
Just wanted clarification on something. In the top section of your ad write up, you have listed N1 turbochargers (in excellent condition) in addition to intake side, for what can be assumed as $5500, according to the title of your thread.
However further down you have listed the price as $5500 without said turbochargers, and $6500 with. The Trust turbochargers don't interest me, but if the N1's are R34-spec, and for $5500, that would be a good buy.
Keen to get some more info.. Thanks in advance.
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
