They sound like the stock rims right?
42psi is pretty darn high, probably the max tyre pressure it can handle (check the sidewalls). On my S14, the tyre placard recommends 29psi but thats a bit too on the comfort side. About 32-34 should be cool :)
I run FM901 225/50/16 on a 7.5"rims, 32-34psi gets the best out of them :D
Over 40 is a tad too high, and your tyres will wear the middle out a bit quicker. Also should get less grip at lower pressure too, but all depends on the tyre itself
I think 42 is a little high, but I would be aiming for around 38 (we are talking cold, right?) They should then come up to 42-44 once hot for nice handling :D
Can vary depending on the actual tyre tho, you may want to check with the manufacturer
42 is not too high, in fact 40 is the minimum you need if you hit the track regularly.
In fact 36-40psi is the majority of operating pressure of most tyres. Tyre placards are
a conspiracy used by car manufacturers so they can sell cars, since customer will feel comfortable bounce on their bums when test driving a car from the showroom.
For the street it all depends on rims and tyre combination. if you fit a wider tyre 225 onto a narrow rim like 7", then you need to pump it up to prevent too much sidewall flex, e.g. I find 36psi on my 225/50/R16 on stock R33 16" rims gives the best turn in response. If you put 225 tyres on 7.5" or 8" wide you may be able to run less pressure, maybe 32-34.
you'll need to experiment to find the best. I always find running at least 2-4psi above recommended pressure on the tyre placard works best.
decided to put it back down to 36...though at 42 the car felt slightly less sluggy in the rear end. will try 38 next time. i assumed 42 cause when i got my front tyres swapped over to the new rims they were pumped at 42 by the tyre guys.
by the way...has anyone used those auto pumps..the one with the digital display?? i aint too sure about those things. i set it to 36 so it would deflate the tyres from 42 rite...then i get an error then it says its 32 so it starts pumpin then i get another error and it says the tyres now 50psi so it deflates for a sec then another error and it says 35 so it pumps again and then another error and it says 59psi..WTF?? i felt the tyres and shat myself thinkin it would explode or something. took the hose off and deflated the tyre with my keys. who knows how long this would have gone for...sheesh.
Those digital ones are generally more accurate since the pressure sensor is not being thrown around to the ground like some older conventional ones.
However they are not perfect as I found:
- They cannot be used to inflate a totally flat tyre as it needs some pressure
feedback from the tyre to sense how much air it needs to pump into the tyres
to reach the target pressure.
- If the target pressure is too far from your current pressure (e.g. from 24psi to
36psi) they often overshoot and had to deflate, overshoot the deflation and
has to inflate again.
if you don't connect the hose properly this can occur, I have to hold the hose in position and then it works fine.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
