walky01 Posted February 25, 2014 Share Posted February 25, 2014 hey guys, i recently posted up why my VCT was leaking, bought all parts and now it seems like my Bolt holding the VCT camgear in is out too much, the washer looks very thick, not like a normal flat washer, is that normal? the bolt sticks out so much that i cant put the VCT cover plate spring and 4 little bots on. an help appreciated ! Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/ Share on other sites More sharing options...
Dose Pipe Sutututu Posted February 25, 2014 Share Posted February 25, 2014 hrmss.. are you running stock cams? Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210251 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 well, stock but reground... i can get a close up of the nut/bolt ill do it now Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210258 Share on other sites More sharing options...
Ben C34 Posted February 25, 2014 Share Posted February 25, 2014 Check that you can use vct with the cams Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210263 Share on other sites More sharing options...
Dose Pipe Sutututu Posted February 25, 2014 Share Posted February 25, 2014 if you jiggle it you will feel there's a groove it goes into, I suggest you pull off the timing belt to get in into place once it goes into place then hold the cam with a wrench and torque up the nut.. it will then sit flush and allow you to put the spring/cover/seal on Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210265 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Ive never taken the cam gear off, why would it have been loose or not in enough? Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210271 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210280 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210281 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210282 Share on other sites More sharing options...
Simon-S14 Posted February 25, 2014 Share Posted February 25, 2014 Sure they aren't rb26 cams reground? Does the bolt bottom out if you remove the washers? Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210285 Share on other sites More sharing options...
Ben C34 Posted February 25, 2014 Share Posted February 25, 2014 Because you have different cams I would not activate vct until you know you can. Cams with more overlap cant run vct or else the inlet and exhaust valves could hit. Obviously you need to fix the leak though but dont plug in the solenoid until you are sure its ok. Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210286 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 they are standard rb25 cams reground, the engine has gone through two guys here, dondenaso (i think thats how you say it) and Skit_r31 both same setup.... not sure if you have seen them on here before, in the n/a section. Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210290 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Sure they aren't rb26 cams reground? Does the bolt bottom out if you remove the washers? Can i fit just a standard washer? does it need to be a special thickness ? Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210295 Share on other sites More sharing options...
Dose Pipe Sutututu Posted February 25, 2014 Share Posted February 25, 2014 ^ yes need the right thickness the VCT actually advances the cam itself, hence there's a notch it needs to sit on Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210299 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 I'll take off the nut and washer to make sure it's correct tonight I'll post more pics Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210321 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210429 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210431 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Thats everything that sits in it. i thought there should be holes or something to let the oil run through the bolt ? Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210432 Share on other sites More sharing options...
RRob Posted February 25, 2014 Share Posted February 25, 2014 LOL... That is the incorrect bolt/washer assembly. Also the origional bolt is hollow down the centre to let the oil through into the gear. Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210436 Share on other sites More sharing options...
walky01 Posted February 25, 2014 Author Share Posted February 25, 2014 Thought so, are the two washers supposed to be there? Link to comment https://www.sau.com.au/forums/topic/439725-rb25-vct-camgear-bolt-too-far-out-need-replacement/#findComment-7210438 Share on other sites More sharing options...
