Howdi everyone,
i've been thinking ALOT about where to next with my skyline. my modification list is as follows
PowerFC
z32 maf
850cc injectors
GTR Fuel pump
Evo 3 intercooler (stock piping positions)
greddy type rs bov
factory exhaust manifold
hi-flowed factory turbo.
i've been following and looking at the posts regarding the GT3076R turbo and noticed this turbo can fit with the factory manifold. my end power goal is a reliable 450-500hp
what is possible with a turbo like this and keeping the stock exhaust manifold?
That's upwards of 340rwkW and is therefore still within the ability of the stock manifold to flow, but getting well up toward the top of what works. So you'd do well to look into die grinding the runner ports a little to open them up, but particularly at the outer ends where they don't tend to line up with the head ports as well. Clean them up to get better alignment basically. Maybe a little tickle into the collector.
The best thing you could do though would be to look at the Hypergear thread and see what he has done (somewhere in the last 10 pages) to a stock manifold. Makes it able to support a hell of a lot of power by fixing it so the wastegate flow doesn't have to go through the collector into the turbo housing. (Obviously for mounting an external gate on it). It's not a trivial mod, but almost anyone half handy should be able to do it.
Thats good information to know.... i think i'm probably being a tad optimistic for that power figure given that my donk has done 300,000kms now....perhaps 300rwkw is more realistic. will mosey on over to the hypergear thread.
its fine...i've just changed the oil...it drinks probably half a litre between oil changes? i put 5 litres in and about 4.5 litres come out. i've just tidied up the tune so hopefully its a little better now...was running 9 afrs @ wot prior to tune for a good 50-70 thousand kms.
I've had a 6boost twin scroll and a stock manifold with a GT/GTX3076 setups on same tune and was running around 320-340kw, both felt the same on the street which was unexpected, the 6boost has larger and longer runners and collector which in comparison to a stock
manifold might effect things negatively on a street car?? just my opinion
Edited by AngryRB
Yeah when i did my manifold studs and gasket last i took to it with the die grinder and took all the casting marks off and tried to port match the end manifold ports a little better...its quite the lip isn't it!
300-350 is usually considered about the safe area for stock manifold that sees some hard duty... I'm sure you can always push 400 through it but question is, do you really want to...they are already prone to warping and cracking. Of course if it's only a street car that does the occasional skid, its not really going to be an issue though.
With a big enough turbo you should see 450wkw through the stock manifold, but it will become a restriction at much less. You should be fine with 340kw on the right setup.
Obviously the better flow from a good aftermarket manifold helps with the top end, but larger runner manifolds also take longer to build pressure, causing the turbo to be slightly less responsive down low. They are also illegal so I only like changing to them on track cars, otherwise there is a good chance you will get defected the minute the bonnet is popped.
Just remember, the manifold grows considerably in length as the exhaust temp rises. I imagine the ports would line up fairly well when the manifold is cherry red, as it could be around 10mm longer than it was. The water cooled alloy head wouldn't expand anywhere near as much.
The manifold is clamped to the head. I would tend to think that the thermal expansion turns up as stress in the cast iron rather than much actual dimensional change. Otherwise the fasteners will be sliding across the flange surface and the flange will be sliding across the gasket and everything should turn to poo within a few hours of operation (ie fall apart and start leaking).
Edited by GTSBoy
That is exactly what happens, and why you need large thick washers under the nuts. I wonder why the manifold studs are always snapping...
Clamp the manifold down to tight and it will transfer the stress into the manifold, good chance it will crack not long after, unless the stud lets go first. I would be torquing them down to manufacturers specs with oem gaskets, I am sure Nissan did a fair amount of r+d on the subject.
How do conical washers allow for expansion along the plane of the flange?
Conical washers are a SPRING washer. They allow for expansion along the axis of the bolt/stud so that they don't get loose through heat cycling.
The thermal expansion along the plane of the flange is the reason that studs end up breaking. They get worked from side to side.
I'm surprised I have to explain this stuff.
