Tuned Performance Dyno Day - 22/03
Cadmoon, what mods do you have?
The RB20det in my Silvia has 210hp at the wheels with stock turbo and injectors, only mod is a intercooler and exhaust.
Also it has leaking intercooler piping which is not helping the fact.
The RB20 is generally underrated , in a light car like an S13 it will leave most SR20s for dead.
I have since changed the Turbo to a GT2860rs I have a Niztune ECU, 660 cc injectors and a Z32 AFM ready to go in, should make around the 300HP atw, not too bad for a car weighing under 1.3 tonne.
Hey guys, just to let you know I tune Nistune ecu's. I'm currently talking to Matt at Nistune about becoming the brisbane dealer.
  • Like 1
All I have power wise on mine is 3" turbo back exhaust, front mount, turbosmart boost tee running about 9-10 psi, yellow jacket coils and a pod filter in a home made air box with cold air intake.
Yeah I've heard a few people say the RB20 is a good motor to put in Silvias.
Yeah they are good in Silvias. They fit well and aren't too much heavier then the SR, but the best bit is it doesn't sound like a tractor. And you can have everyone's hand-me-downs as performance mods.
Good to hear Deren, could you please PM me your prices for dyno tuning as I will be looking at getting my car tuned in the next few months.
  • 3 weeks later...
Just had Deren tune the S15 and it went from 223 on the dyno day and now has 257hp and it comes on boost so much earlier, totally different car to drive, would reccomend it to anyone thinking of getting work done
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
