I recently had to charge my flat battery ( not using car very much at the moment) and when I attached the neg lead back to the battery (with pos obviously already connected) I accidently (and clumsily) touched the ratchet used to tighten the nut between the neg and pos terminals of the battery resulting in big spark and me jumping quite high.
The car has been used since then and everything seems normal, but my question is could there have been damage to the electrics and/or the battery?
Many thanks.
https://www.sau.com.au/forums/topic/439770-accidentally-shorted-battery/
And the ratchet would glow bright yellow and then melt before the battery went flat anyway. And in the meantime, the only effect at the ECU would have been removal of power.
The real problem you have heard about (although obviously not correctly) is reverse polarity connection. Hook up a jumper battery or car backwards and see what happens to the ECU (which may be nothing, depending on how good the RP protection is).
Edited by GTSBoy
Realistically, the welding thing is perfectly true. Or at least it used to be. And it isn't the battery terminals you need to remove. The ECU needed to be unplugged from the loom to prevent it from getting nasty zaps up through the earth connections.
More modern cars and ECUs have much better protection against this sort of thing so you can get away with it. But back when all this was new, many ECUs and other vehicle electronics were damaged by welding.
Well it shorted through my ratchet, so it should be fine, only thing would be the ECU that would be damaged if left on long enough and I would have known by now if it was wrecked. Are there any other components besides the ECU that can be damaged?
Think about it, Your shorting a battery accross the terminals. Basically you are bypassing everything between the positive and negative circuit in the battery. The only damage will be to your ratchet.
Unplugging sensitive electrics when welding is a good practice to do, in theory if you have the earth lead close to where you are welding (and provided it isnt near an ECU etc) then the chances of damaging it are minimised Because the circuit wants to take the shortest route to the earth lead. So if the earth lead is at the back of the car and you are welding on the front reo bar, you can imagine that the circuit is much more likely to join with the ECU circuit then if you have the Earth lead closer to the welding area. Having said that, I would never weld on a car without unplugging ECU's etc because its alot of current to pass through the chassis
Shorting across the battery terminals is not much different to shorting from the positive to the chassis (because the Battery negative goes to a nearby Chassis earth anyway)
The most likely thing you will damage is the battery. This is a bit more of an issue if the battery is in the boot, has been through some charging cycles and there is hydrogen gas around. Arcing the terminals can result in battery explosion. I've seen plenty of horrible photos of people messing with batteries in dump trucks/dozers where this has happened and the battery is a mangled wreck.
Summary:
Shorting battery terminals, not advisable but generally doesnt end in disaster
Welding with ECU's plugged in: No
Edited by 89CAL
Remember that some ECU's require a 5V power source for sensors and dont generally like higher voltages then that.
OHMS law proves that voltage is proportional to current. Voltage goes up, current goes up
Edited by 89CAL
Welding........much more than 12v.
And much more current then you will find in your fuse box in your car :)
Some people are lucky and get away with welding with everything still connected, but for the small amount of effort it takes to unplug stuff, its not worth the risk
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
