Gday All,
A couple of times recently while driving the rb20 cefiro ghettomobile, the engine randomly lost all power, like I'd switched the ignition off. By pumping the accelerator it will then fluttered a little then pick up power and continue driving normally.
I replaced the ignitor and cas then drove it last night and the problem is still there, its also hard to start.
Its an R32 RB20det running in an A31.
Should i be looking at TPS, the AFM or what?
Thanks for any help or advice you can offer,
Agent A31
Thanks for your reply, Its a bit of a weird problem.
I will investigate the AFM and give it a clean for starters.
Its not a missfire because all cylinders lose power at the same time stay off for a few seconds then return,
so Im thinking its probably not coils this time. (Ive had dodgey coils before and been through that).
Fuel pump is a bosch 040 not a 30 yr old flogged out nissan job so Im leaning away from that option too.
thanks very much for your suggestions
Agent A31
  • 1 month later...
Ok sorry to drag this up again fellas but Ive still got this problem.
So far:
-my coils are fine
- Ive cleaned the z32 afm- is there anyway of checking this or do I just have to bite the bullet and buy another if I suspect it?
will be checking fuel pump next.
Thanks for any help
Agent A31
Ok so today I pulled out the 040, it looks fine with only about 2 specs of dirt on the mesh filter. I put in back in and pulled off the fuel supply hose to the engine, with ignition on it pumps quite a bit of fuel so Im guess the pump is ok and I should start looking at the AFM.
Anybody got any more suggestions?
Thanks
Agent A31
You need a pressure test on the pump. Just because it pumps a large volume with no restriction, doesn't mean that it can keep up when the backpressure rises. Plumb fuel pressure gauge into fuel line and see if it maintains pressure as you run the engine at load.
Having said all that, it probably is the AFM (or something else electronic).
Hey mate, cant think of any particular circumstance causing this, it happened once immediately after I gassed it hard and changed gear, another time while cruising at steady highway speed, so seems a bit random? Any more details of your own situation?
AgentA31
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
