A computer won't find it, I assume the metal ring the sensor picks up is damaged. If it's the front, it isn't the same as the awd Stagea pickup, this is your rwd sensor, the front one seems to be built into the wheel bearing.
http://www.conceptzperformance.com/cart/description.php?II=13678&Car_Type=NIS350&UID=20140305040927122.151.165.189
http://g35driver.com/forums/brakes-suspension/431954-abs-sensor-wheel-bearing-hub.html
I see. So this sensor will correspond to the brakes applying on cornering?
Ill be thorough and get the computer check regardless to rule out the ABS system and i will get them to check the sensor. It does it to both wheels though, not just the left one.
Those sensors and pickups are the only feedback the ABS computer gets from the wheels. If a front wheel has fallen off and the hub dragged down the road, that is the side I would be checking over thoroughly.
Back to square one!!
Scans came back clear. Front radius arm bushes are shagged but he said doesn't cause my problem. Speed sensors and steering adjustment AOK.
Just putting the feelers out...can you guys attack corners and sweeping bends in a spirited run?
My other friends V35 does very similar but not as often as mine.
Apparently the yaw control kicks in when the front wheels are about to go.
My friends VE had loose brake pads up front and his did the same thing as mine. That is my next step, new brake pads. I will also switch back to the old wheels and then see how i go.
I remember when i first bought this car and drove chain of ponds in SA, i could thrash it, no steering problem.
Very frustrating!!!
Anything that could cause the car to turn more or less than it should for the steering input will trigger VDC.
Compression rod bushes could do this is they are bad enough.
I've competed at Collingrove hillclimb numerous times in a 350GT coupe - factory springs & shocks & whiteline swaybars - and never had anything like what you are describing. I reckon you could call it a spirited run.
I do turn VDC off before each run - tried it once with VDC on and it cut power as I went into the first corner.
SOLVED!!!
What year is yours?
I think the problem may lie with aggressive VDC in the 03 models. There is a Yaw sensor underneath the cup holders. I unplugged that after a bit of research and WALA! I just drove through the hills with no problems what so ever! Slip and VDC OFF remain lit up, but if that's all it takes then I'm all for that.
I will mock up a little rocker switch for on and off control soon.
It is amazing to be able to drive "spirited" again.
Wow!
Well it depends on what the mechanic means with 'front radius arm', I am assuming he is talking about the lower control arm or compression rod?? Since you have had the lower control arm bushes changed, I can only assume he is talking about the compression rod bushes which are also a common problem on these cars.
VDC on my 05 will not bother me unless a wheel actually slips. It is quite sensitive and as soon as you get even the slightest bit of slip it will kick in and correct it. However, I have never had VDC kick in without first feeling or hearing some slip.
That said, the rear on my car is a bit too happy to kick out, especially in the wet and the VDC often has to catch it.
Traction control is not the same as VDC, although some do confuse the 2.
TC only keeps your driven tyres from spinning when excess throttle is applied.
VDC monitors steering wheel angle, individual wheel speed and a Yaw/G sensor attached in the middle of the car, and if it detects any loss of control it can cut engine power and apply brakes to individual wheels to correct it.
Edited by sonicii
wow learned something new today lol
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
