After seeing some dyno sheets of the hypergear atr43ss2 i think it'll be a bit laggy for me.
Does anyone have any opinions in terms of response on INTERNALLY GATED kinugawa td06-20g-10cm and hypergears atr43ss1/pu or their op6 highflows?
I've got so many people telling me mixed sht I just want some opinions which will be best for the street. I want full boost as EARLY as possible and want to be around the 280rwkw mark.
Keeping in mind the td06 is $500 cheaper too
Rb25det fresh forged
E85
Tomei 256 cams
Supporting mods
Std manifold / int gate
Cheers
https://www.sau.com.au/forums/topic/439786-kinugawa-td06-20g-10cm-vs-atr43ss1/
The two turbos are not comparable.
280rwkw maximum response on E85 a 2IU highflow from hypergear will get you there.
Why aren't they comparable? How much bigger is the td06? 280 was on the low side, ideally I'd want a turbo capable of 300awkw but not if it'll sacrifice too much street ability
An SS1 is comparable to a garrett GT28 in size, a TD06 is comparable to a GT30 in size. I trust you know the difference between a 28 and a 30, its fairly major.
You also will struggle to see 300awkw from a TD06 20G, which we have covered recently in another thread. In fact, the forum arms you with more than enough information to form your own opinion on the topic within an hours reading. The Hypergear thread is not only indexed with SS1 results but ALSO TD06 based results.
Go to the hypergear thread and fill your cup.
Edited by GTScotT
  • Like 1
Do you really consider full boost by 3700 as laggy?
Its not 'laggy' but i think its a bit big for what i want. For a street car that barely sees redline and seeing as I'd be happy with 270-280kw on e85 I think it's overkill.
Could just go smaller rear housing I guess
I've found a garrett bb turbo that's probably a little on the big side but it should do the job. Priced well and internal gate. Made 273kw at 16psi on 95 no cams. Makes 100kw at 3000rpm which seems good
Money is also a big factor seeing as this has all blown out 10 times what I expected.
Ill do a build up thread
Std high flow makes 100kws at 3000RPMs and maxing out at 320rwkws on E85. Note this turbo hit 20psi at 3400RPMs, there isn't many turbos out there can do this without chocking the engine tho. Pump 98 fuel usually makes 40kws less. It is cheaper then what cost you to buy a TD06, after testing all this TD06 based turbos, I'm fairly sure it is far more responsive then any thing based in a 10cm turbine and makes more power internally gated.
Added 270214:
labeled dyno reading from 21U high flow internally gated on Stock manifold E85 (take 40kws off for P98 result)
my tdo6 almost makes 100kws at 3000rpm ( well 90 but at least my graph is clear..)..and makes more torque at 3k than anything you just posted Stao...it is Externally gated though, internal gate tdo6s are fail
Give your Hypergear a run for its money anyday :P....
its also for sale..full bolton kit....buy it ;)
I would if it was internal gate.
I'm still trying to get my head around the hypergear range. What's bigger, the ss1 or the op6 highflow? What is the ss1pu? What physically LOOKS bigger? Stealth is also a contributing factor as I'm in big trouble if I need to go to the pits with a 25 on e85 in my 32
why not feed your highflowed RB25 turbo with E85?
isn't it already installed on your motor?
That turbo is being replaced. It's an rb20 turbo and it's tired. Obviously if I already had a rb25 highflow I could use, I'd use it.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
