Kris.. Posted February 26, 2014 Share Posted February 26, 2014 So I have a s1 rb25 getting tuned right now and the injector seals are leaking Has genuine greddy plenum Top feed injectors and rail I used the standard rb25 injector seals in the plenum and they leak? Tuner says I need some alloy bucket seals but every 25 I've seen are just running the standard seals and all the googling says to use standards aswel?? Link to comment https://www.sau.com.au/forums/topic/439798-leaking-injector-seals/ Share on other sites More sharing options...
scotty nm35 Posted February 26, 2014 Share Posted February 26, 2014 I have some here if you need them Kris. Can you get a pic of the seals you need? Link to comment https://www.sau.com.au/forums/topic/439798-leaking-injector-seals/#findComment-7211830 Share on other sites More sharing options...
GTRPSI Posted February 26, 2014 Share Posted February 26, 2014 Were they new ones put in and leaking or did you reuse your old ones? Sometimes if you instal new ones dry and its a tight fit you can damage them. Link to comment https://www.sau.com.au/forums/topic/439798-leaking-injector-seals/#findComment-7211859 Share on other sites More sharing options...
Kris.. Posted February 27, 2014 Author Share Posted February 27, 2014 I have some here if you need them Kris. Can you get a pic of the seals you need? i think i may have sorted some but theyre in the pic of this ebay add, if they fall through ill be sure to contact you thanks man http://www.ebay.com.au/itm/Top-feed-Nissan-R32R33R34-RB25DET-ALUMINUM-FUEL-INJECTOR-RAIL-/200967868813 Were they new ones put in and leaking or did you reuse your old ones? Sometimes if you instal new ones dry and its a tight fit you can damage them. i used brand new genuine nissan ones and they slipped right in Link to comment https://www.sau.com.au/forums/topic/439798-leaking-injector-seals/#findComment-7212371 Share on other sites More sharing options...
scotty nm35 Posted February 27, 2014 Share Posted February 27, 2014 Yep, I have a set here if you need them, with Orings. Link to comment https://www.sau.com.au/forums/topic/439798-leaking-injector-seals/#findComment-7212423 Share on other sites More sharing options...
