post-75861-0-49393000-1393414738_thumb.jpgpost-75861-0-38387700-1393414751_thumb.jpgpost-75861-0-72720400-1393414770_thumb.jpgpost-75861-0-16604200-1393414785_thumb.jpgpost-75861-0-21287600-1393414800_thumb.jpgpost-75861-0-12426200-1393414817_thumb.jpgpost-75861-0-63846500-1393414847_thumb.jpg
For sale
HKS Kansai Service 280kmh dash cluster 90,000km $250 ono
280l Sard fuel pump (brand new in box) $300 ono
Carbon fibre rear strut brace $85 ono
HKS PFC F-CON & HKS EVC (only whats in pics) $100 ono
A-pilar Carbon fire 52mm dual gauge holder $90 ono
52mm Auto Meter carbon faced oil pressure gauge (brand new in box) $80 ono
52mm Auto Meter boost gauge (only in car for 3 months) $60 ono
Mark 0402699609
  • 3 weeks later...
  • 1 month later...
Price drop for Sard 280l fuel pump $250 ono
Rear strut brace $60 ono
Also now have power fc hand controller only $150 ono
Serial number FCC3 020-25258 (came off D-Jetro out of R32 GTR)
Very good condition
  • 7 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
