Hi All,
Purchased a 2001 Y34 Cedric some years ago. We also own an '97 Nissan R'nessa wagon, nothing exciting but a good sized and very practical vehicle, has a SR20DE engine.
Really love the cedric but would appreciate some help with trying to track down an enlish translation to the computer screens and the other problem I have is that it has recently started to randomly beep.
I know that there are some translations out there and would appreciate if one could be sent my way to [email protected].
Beeping was after a couple of hours driving but more recently is down to half an hour or so, getting what looks to be a picture of the front of the car come up on the screen.
https://www.sau.com.au/forums/topic/439836-y34-cedric/
  • 5 months later...
  • 4 years later...
