I still have that set of wheels here if you still want them
I was think of just getting a standard replacment one like this
http://www.ebay.com.au/itm/RADIATOR-NISSAN-STAGEA-M35-V35-AUTO-MANUAL-2002-2007-KOYO-BRAND-NEW-/171244943165?pt=AU_Car_Parts_Accessories&hash=item27defe773d
https://www.sau.com.au/forums/topic/439841-m35-radiator/#findComment-7212719
I haven't seen the fitment of those, and considering the V35 and M35 radiators are different... Who knows how it slots in.
Wasn't it a V35 one you fitted in my car last year? I think it was a little higher, and you had to trim the shroud a little to get it all to fit, but you reckoned that it was straightforward...
https://www.sau.com.au/forums/topic/439841-m35-radiator/#findComment-7212998
Wasn't too hard to fit, but definitely not drop in. I think I had to trim about 15mm off the end of the shroud so it wouldn't rub on the fins. I remember the core being about 2 inches wider or something.
Just make sure you bleed the system real good after.
This is true. Keep a good eye on the gauge for the first few drives, also check the rear bleed point and the overflow when it's cold the next morning.
https://www.sau.com.au/forums/topic/439841-m35-radiator/#findComment-7213013
M35Woah had a positive experience with the Alloy Fenix rad I think he got off eBay
Fit without mods. Just make sure you bleed the system real good after.
+1
Fenix Radiator
Ebay fenix radiator, fits almost perfect. Just mention to them you want it for an auto. I think I got mine the same day I ordered it.
The seller said I may have to trim the shroud but we didn't bother, the thermos are still really efficient.
https://www.sau.com.au/forums/topic/439841-m35-radiator/#findComment-7213148
Just remember, completely different setup above, no clutch fan and the shroud has thermo's instead. I don't think you can compare it to the NM35 for ease of fitment. I would want to fit one before saying it was drop in, as all the aftermarket radiators I have fitted haven't been.
https://www.sau.com.au/forums/topic/439841-m35-radiator/#findComment-7213166
Thought I should update this
I ended up buying this one that I linked to earlier. I was able to pick it up locally so had the car sorted out Friday night
It was 100% drop in. Didn't have to trim a thing everything hooked up perfect.
  • Like 1
https://www.sau.com.au/forums/topic/439841-m35-radiator/#findComment-7220174
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
