Hey,
I've just ordered a Tomei fuel pressure reg, and noticed I shanked it. I've ordered the type L which is for high boost setups.
Here are the specs:
I've got an R32 GTR, HKS GTSS's, poncams, 700cc injectors, HKS Fuel pump, HKS turbo back. Can I still use the type L for 18-22psi?
Or should I cut it away and get the type S?
You should be OK. It will try and maintain pressure at X+manifold pressure, so a larger valve will need to be slightly more closed than a smaller valve at the same pressure.
If you are really worried borrow a fuel pressure sensor and hook it up to the regular before starting the car. You will quickly see if it is holding the correct pressure at idle - which is when the regulator is doing the most work.
Hope that makes sense!
Also, I think high boost / low boost is misleading terminology to use for a fuel pressure regulator.
Remember the regulator is controlling the return from the rail, not the feed.
So, a regulator needs to be sized so it is large enough to return fuel from your fuel system at idle.
A larger fuel pump requires more fuel to be returned.
On boost, the regulator is returning less fuel, as more is going out the injectors.
Therefore, it follows that higher boost means less fuel to be returned.
In summary a fuel pressure regulator is not sized based on boost or power output, it is based on fuel flow rate at idle, which is when it will have to return 95% of the fuel flow back to the tank.
Yeah thanks for that. Think I'll just cut it away and go with the Type S. Wasted money and potential by the sounds of things.
If you are ever planning to go to a larger fuel pump then it is one thing you won't need to upgrade.
What is the max power rating of the HKS pump?
Nothing wrong with stock reg. How much power you chasing? Why change it?
That depends entirely on the pump setup, for example the stock regulator will not be able to control the pressure if you have 2x 044s behind it.
For the HKS pump on the other hand, yes it would likely flow enough just fine.
  • 4 weeks later...
won't that just mean it will return more fuel to the tank? doesn't the regulator open above 43.5psi?
Yes it will. Seen it on more than one setup, both Nismo and factory units with duel 044's.
OP, you'll be fine although it's not needed.
Interesting to know!
Do you know if the dual 044 setup pressure lines were T'd together before feeding the rail, or was the rail dual entry centre return?
In my case each 044 has its own pressure line leading to each end of the rail. Which is why I went with a aftermarket FPR off the centre of the rail.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
