Hello again,
I'm wondering what is required to fit a wideband o2 sensor in place of the factory narrow band?
i have a powerfc...
if this is not the ideal location for a wide band...what is?
thoughts? i'm tossing up buying an innovate wideband kit but trying to decide between a permanent install with gauge and input into the fc datalogit or..just go for one that i can move between cars with.
Installing a wide band sensor in the factory O2 location will result in a shortened life span.
You will find plenty of useful info here... http://wbo2.com/lsu/lsuinstal.pdf
and here...http://www.techedge.com.au/
EDIT: not all WB equipment will allow you to simulate O2 readings that your computer needs so an O2 sensor may still be required.
Edited by Missileman
There's alot of info that says thats not the recommended spot.it is too hot. Some have no worries though, its your money and sensor to gamble.
It would cost stuff all to get a bung welded onto the exhaust in the right spot. Thats what I am reccomending.
Cost me $25 for bung and my local exhaust shop to do the welding.
My panel beater mate was enjoying burleigh heads at the time, so he cost me an extra 10er
Most run the narrow in the original place and place the wide further down away from the high temps.
I still amazed to see so many running a wide band sensor very close to the turbo outlet and then complain that the sensor keeps failing and blame the brand fitted.
cool thanks for all your inputs appreciate it. Given this i think i'll save my money and get the proper innovate kit with the innovate exhaust probe and just run it through boot along the side of the car and in the window.
does anyone have any other knockblock recommendation. I've been looking at the link knockblock....they are about $800
its cheaper to rent tuner ears, but much more difficult to accept the results...:(
    • Great to hear you are bringing it out of the shed again. Unless you have specific issues I'd just add the wideband, get a good tune and enjoy it. Certainly no point changing coils etc if they are working. If would add fuel pressure and e85 sensor if you are doing a general update but not if it runs OK and you are just getting it back on track. The other thing is smaller, modern twins, -5 are OK for motorsport but pretty laggy and old tech for street use (of course, if performance is the priority a modern single with twin scroll manifold etc is the go but not cheap). The final thing worth considering is switching to an ethrottle if drivability is still an issue, it should make things a lot simpler and smoother
    • Yeah pretty sure they are m4, but best to check, and perhaps use new hardware Also don't over torque them......there was that one time I lost an expensive engine after a workshop overtorqued one of those bolts and it ended up in the oil pump (no, I don't know why they removed the intake mesh either)
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
