Hi guys I have a r32 gtst it is mostly standard, now the box that was in the car was screwed not bye me so I got a used one from KYP in Perth and hyperdrive fitted it. But some times when I change into third and fourth it crunches and knocks but only when the box gets warm. I thought it might be the oil being to thin so I got thicker stuff and it's not as bad but still does it sometimes so I was wondering if it is bad to put to thick of oil because I might try thicker stuff.
https://www.sau.com.au/forums/topic/439903-r32-gtst-gearbox-crunch/
Redline Lightweight Shockproof
Nulon G70 Gearbox & Differential Treatment
If that doesn't fix your issues nothing will, meaning you've bought a dud gearbox.
Film thickness greater than an SAE 75W140, yet low fluid friction like 80W gear oil or 30W motor oil.
  • Like 1
So it wasn't the oil I had a look at the clutch pedal and changed some stuff and had a fiddle. I think the clutch was set wrong because after I changed it it was a lot better it still makes some noise but doesn't fight me when I try to change gear it's all smooth to shift now so I thought I'd let u guys know
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
