Hi all,
I have a r34 gtt with (130k on the clock) and i was involved in a hit on the passenger side of my car with a road barrie. The front quarter panel, rear panel and both front and rear bumpers were effected. Mechanically everything is fine, no leaks or anything major in steering alignment, and no structural damage at all. All cosmetic!
Going through insurance, they have claimed market value (i know, i shouldn't have chosen this option, but i did) to be 8-11k. Mechanically, everything has been kept pristine with no leaks/rattles/knocks etc. And they wish to salvage it for 5k!?
I've put the past 2 years into my baby, and I do NOT want to see it gone for cosmetic damage. I'm bloody devastated. I'm waiting for the final verdict on Monday, but it does NOT look good at all...
Looking on carsales, the avg price is 13-15k, how the hell did they come up with such a low figure?
Can anyone give me any advice which may work in my favor to bring insurance company to repair this :(
https://www.sau.com.au/forums/topic/439915-insurance-enquiry/
* Not many people think that by taking out such a policy based on "market value" rather than "agreed value" that they'll have to make an "at fault" claim, except if it was stolen.
* Insurance companies are investment businesses and they are not compassionate or enthusiast-minded. Their skyscrapers are not built on compassion.
* Should you not be able to "part out the car" for a heck of a lot more money than to proceed with the claim for only $5,000?
* If you prefer to part out the car, do you realise that you don't have to carry the burden of "suffering a total loss" and "being at fault" when you apply for a future insurance policy?
Otherwise, future "premiums" will be noticeably higher!
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
