Edited Post 6/7/04
Car: 1989 R32 GTR
Gun metal grey
Damage: Engine bay fire (Electrical).
Parts for sale:
(Parts listed below are whats left)
Radiator $50(header tank burnt,some plastic melted on core) Can be scrapped off
GTR intercooler and piping $450 SOLD
Front bar $500
Front Grill SOLD
Front headlights $300 pair
front side indicator lamps $200pair SOLD
FET air filters(red) $70
R32 GTR Air flow meters $150 pair
R32 GTR 16x8 rims with tread FAULKEN ZIEX tyres $1100 (rims immac. cond)
R32GTR brake system (calipers and discs all 4 ) $1500ono on hold
3 inch s/s HKS exhaust system from Turbos to muffler sytem $1300
Rear wing $300
Original stock GTR shocks and springs $700
Front passenger Panel (needed repainting) $200 SOLD
bonnet catch $50 SOLD
Driverside rear complete tail light
Passenger side original side skirt
Contact
Ray 0400 805 168 or
Jay 0410 314 710
https://www.sau.com.au/forums/topic/43992-fs-damaged-1989-r32-gtr/
  • Replies 57
Check your PM or email me at [email protected]    ... thanks
assuming the front bar is fine i'll take it.
will need to be couriered to me in melb though
i take it GTR front bar's fit straight onto GTSt's
Cheers
PM me and we can work something out or email me at [email protected]
Thanks
I'll take the rims, the front grille and the headlights off ya. Can you contact me via email [email protected]
I'll SMS you around midday today about it. How far away from Dundas are ya?
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
