hi guys i have an r33 GTST my set up consist of
gcg highflow turbo
s15 480cc fuel injectors
link G3 ECU
GTR fuel pump
FMIC and 3' turboback exhaust
my aim is about 240rwkw plus, is it possible with this set up?
yes and those injectors are 448cc at 3bar NOT 480cc
Those injectors will work for what you want to do, you can use them now and sell them later when you decide that you want more. No need to 'upgrade' to 550s which are equally as redundant.
As for the package listed and if you will get the power, the answer is a simple yes. The only thing you need to be aware of is the GTR pump which is probably 20 years old. Be it myself I would run what you have but would buy a walbro NOW to save the heartache of pump failure later.
The SOSK R33 did 266 on PULP though it had GTR injectors in a Freddy inlet manifold , 256 Poncams and bit of head work inc the slightly OS exhaust valves .
They had an OP6 turbine housing on their GCG BB Hi flow which help out too .
It used a 32 GTR pump and the pressure was raised a bit with a Nismo reg .
A .
