Driving home late on saturday night I pulled out onto a road after going up a decent hill and the car stalled. I started the car and it stalled again but it started easily both times. The second time it stalled I started it and just drove the rest of the way home with no further issue. Full tank of fuel. My car has nbever stumbled or stalled EVER since I've had it. Yesterday I tried unsuccessfully to get the fault codes but after 5 or 6 goes I couldn't get the CEL to flash. I am confident I was doing it correctly as I had the instructions next to me.
Was this just an anomaly or is this symptomatic of the MAF starting to die? Car has 90k's which I firmly believe are genuine and has never had an MAF in it since I've had it. Opinions?
https://www.sau.com.au/forums/topic/439994-maf-issue-or/
Doesn't sound like a MAF to me; the 2 I've had fail just went without warning.
One whist driving; instant CEL, and spluttered, refused to idle until unplugged. Then would only run to 2200rpm.
Second one failed on startup; CEL light on, and coughed, farted, ran like a hairy goat. Because it was stone cold, unplugging wouldn't really run smoothly.
Maybe Cam or crank angle sensor?
https://www.sau.com.au/forums/topic/439994-maf-issue-or/#findComment-7215667
Yep, mine was cutting out for 4 seconds randomly, probably once a day. It did get worse before I changed the crank sensor which fixed it.
Sometimes just cleaning the crud off the sensor will help, the starter shaves off little pieces of metal from the ring gear which magnetize to the sensor, limiting it's ability to pick up the flywheel disk. The sensor is between the engine and bell housing so it's easy enough to clean and replace. Try that before you buy a new one Rich.
https://www.sau.com.au/forums/topic/439994-maf-issue-or/#findComment-7215769
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
