What is the best way to warm up skylines? May seem like a silly question but the reason I ask is this.
With many German cars like BMW the manufacturers recommend to turn the car on, let it idle for a minute and then drive it nice and easy till it reaches the operating temp. This way the motor and gearbox warm up together.
Is this the best course to follow with a skyline or is it better to let it idle till it warms up enough and then drive?
I think I answered my self by posting this thread but would like to see what people think.
https://www.sau.com.au/forums/topic/440009-warmig-up-the-car/
Letting the oil circulate is all that's required > then drive.
Letting the engine oil warm up is all that's required > then boost.
Letting the tyres warm up > then traction :P
Did you know that when you could hire V8 statesmans (many years ago) on a cold start you could apparently hit the rev limiter before the oil light went out? A friend told me.
To answer OP question, don't waste time sitting in the driveway idling. Cars these days (ie for the last 30 years) are designed to drive off as soon as you start them and build up oil pressure. Drive slowly / lightly until it's warm then go nuts.
learnt this with my 32,
had rough valve stem seals and warming it up on the driveway made it smoke worse
makes sence after thinking about it.
however my mate swears by starting it and after 10 seconds revving 1500 rpm constantly bliping it to 1500rpm.
recons it squirts oil up the engine. not sure but meh maby
For those 10 seconds or less.......... I'm free!!!!
  • Like 2
what about warming up built/race cars?
my clutch and gearbox need to warm up before its driveable basically.
and the oil pressure is high and all over the place until its warmed up. So usually start it and either dab the throttle for a bit and leave it for 5-10mins just idling.
With a race car with a crappy tune and animal clutch you don't have much of a choice. I had a group N Daihatsu charade rally car like that once. Yes, despite only 57kW at the wheels it was a pig to drive when cold (stuck with using factory sensors on a very old F7 Haltech, and a bitey 3 puck clutch). Once it was warm it drove like the (underpowered) shopping trolley it was.
I was happy to sell that gutless POS.
Still, if you can drive the car without having to warm it up first, then that's always your best bet.
Don't know about others but when i start my r34 gtt i leave it to warm up until the needle temperature reached it's normal stance which is halfway as it takes
at least 6 minutes but thats just me.
Problem with that, as mentioned above - the oil pressure is at its minimum while its idling, and the ECU is adding more fuel to get it up to temp quicker.
Your way better just driving easily for the first 10 minutes and letting everything warm up together.
In the GTT you've got the advantage of an oil temp gauge - halfway on the coolant Temp needle could be anything. 10 minutes of light driving see's my oil temp stable at 80* and then its ready for whatever
Driveway ildling is pretty pointless, much like idling for minutes after you've stopped to cool your water cooled and oil fed turbo :)
the cold start tune is fine. I'm only following the clutch instructions letting it warm up before driving and stabilise oil pressure.
Thats mental dude.
I don't think we should be looking to you for engine advice, based on your not revving over 3200 rev thread.
  • Like 1
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
