what car/engine are you talking about? i had a friend with an rb30 vl commo and it basically vibrated a shit load when it got over about 80km/h and it was in high gear and running at about 2000rpm so he would have to run it it in power to kick the revs upto 3000 so it didnt make the noise. i believe the noise is purely ****ed exhaust. he insists on running it at 3000 (in power mode) all the time vs getting it checked/fixed
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-899067
Get another resonator fitted to your exhaust, and it should solve the problem.
When my car was NA, I had two resonators and the rear muffler, it may sound like overkill, but the car sounded bloody smooth. When the extractors where fitted, it did sound a little "throatier", but you'd have to know the car pretty well to tell any difference.
__________________________________________________
For sale: Cobe Extractors to Suit RB25/20DE - $200
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-899800
It's been a while since I've bought a resonator, but I'd be very surprised if it cost more than $200. As for fitting, they just cut out a section of your exhaust pipe and weld the resonator in place.
After listening to that attached flie, it sounds like a secondary vibration of some sort, and not the exhaust note. I'd have a good listen to find out where the noise is coming from, it maybe as easy as the exhaust bolts needing a tighten.
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-900147
i recently had to have my resonator changed to get a sticker off - went from 3" hotdog to 2.5", large barrel muffler (stuck in the middle of the 3" piping) and it has a simmilar sound - just over 2750 rpm, it howls so sharply and for sucjh a short time, that i too thought it was a rattle, but when held on the revs, it still makes the noise - it rally pisses me off too... not that it wasn't loud before ;) but at least it was constant... will change it all later, but thats another story (and thread)
good luck with getting rid of that noise mate, coz your right, its nasty !!
:cheers:
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-906222
My exhaust history - standard exhaust had the very noise you are speaking of noise at 2800-3100rpm, but being stock was fairly quiet, then fitted rice cannon, which acted like a huge amplifier and the noise was massively loud , eventually i was pulled over and defected, went to the exhaust shop had a 2.5inch sytem fitted with the largest resonator they could fit, but keptthe cannon muffler, i now get a slightly hollow pipe noise but still sounds decent, the snappy high noise is there but much more muffled and contributes alot to the pipe noise. Personly, it scares ppl cause they think you have some crazy mods or something ???? but yeah, basicly...
Moral of the story - i think its something to do with the cams as mentioned above cause i cant get rid of it, muffle it as much as you can and live with it...sorry buddy
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-911530
dude its called resnonance sp* all na rb25 have it as mentioned about its due to the degree of overlap in the cams, u cant get rid of it, only way i got my car to sound better was hollow cat and 2.5" straight through to a cannon, my exaust is still stting at home if u want it including a set of headers. Its very very hard to get rid of the noise without the car being loud, i tryed different exhaust shops and only fixed it when i started working at a performance shop.
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-911536
Ok, found last night there was a rust hole in the joining weld between the pipe and rear muffler. The noise is really loud when the exhaust is cold, but slightly got quieter when hot.
Trying to find a s/s muffler or cat back system 2.5".
If anyone has or can get it. let me know.
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-925294
a while ago, i had an exhuast system on the NA motor before i swapped over... 2.5 inch system.. the resenator/muffler had a lose baffle inside... it was making the noise at certain rpm's
maybe swap the resonator.. they dont cost much at all. cheap as chips in comparison to fitting new system.
https://www.sau.com.au/forums/topic/44001-bloody-exhaust/#findComment-930486
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
