I have a freshened up T78-33D turbo for sale. Has little to no shaft play. This turbo is rsted to 750HP. Only selling due to switching to something smaller.
Looking for $1100 + Postage.
PM me for my mobile number and I can send pictures.
Located in Perth.
https://www.sau.com.au/forums/topic/440015-greddy-t78-33d-17cm-turbo/
T4 (split-pulse) flanged turbo. 4-bolt rear housing. Trust don't quote an A/R, it's a 17cm^2 housing according to them, which is around the 1.00 A/R mark (correct me if I'm wrong anyone).
Edited by Uncustom
What's the exact front and rear a/r? And what would the turbo hit at on a rb25 with poncams PFC etc? I have a split t4 hks manifold!
As I said, Trust doesn't quote an exact AR on these turbos. On that setup and on a good tune I would expect to see full boost by 5000 RPM.
Cheers.
Mine looks quite similar in size to a Garrett t51r which is. 72 comp housing but t78 has 2.75" outlet, pretty sure the 17cm is around. 82 and the 22cm is about 1.10
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
