Hey fellas,
Kinda dumb question but I wanted to know if you can get fined in a non-metered parking spot? I remember people mentioning Parking Officers marking tyres? Well I left my car in the city between apartments in a 1/4P for a while, 3 hours and 38 minutes to be exact according to the in-ground sensors, which is when the officer issued the fine of $72.
I wrote a letter and my defense was that on that hot day I got stuff in traffic and car had overheated so I allowed for it to cool down before driving it again (the camera in the street can verify this). I didn't call for tow truck or have proof of mechanical repair which is what they want to see as proof to re-review the infringement.
Not sure if they'll accept a second letter but if I write saying all I did was top up the cooling system and had no mechanical work done to it yet, will it be reasonable? or just bite the bullet and pay the damn thing?
Fine is due this Friday the 7th so any input is appreciated :)
https://www.sau.com.au/forums/topic/440027-fined-in-a-non-metered-parking-spot/
Of course you can get fined in non metered parking spots...
All meters do is collect money for parking there and make the inspectors job easier by letting them know how long a car has been there...
No meter just means that the inspector needs to see your car there, and sometimes they'll put a little mark on your tyre, and then come back 15 minutes later and if the mark is in the same spot then the car has been there longer than 15 minutes. If they've got in-ground sensors, then it's just another form of metering without any payment required for the time you park there.
You were in a spot for nearly 15 times longer than was allowed and for some reason left the car... $72 ain't so bad for that :P Pay it and move on.
Some good thought here, thanks :D well I guess if you guys put it that it doesn't sound like I got hard done. Gonna pay it off then.
BTW, does this type of infringement get recorded in your record?
It's a pretty serious offence, if you apply for a job that requires a police check it will come up and you'll probably be denied the position. Also, international travel to certain countries (Singapore, USA and UK in particular) will be tricky, if you're allowed in the country at all.
lololol.
Always the comedian :D
Hahahahahha lawls
don't laugh a ticket for being on a train with no ticket was enough to flag some-one at our work place
dem security clearances
Guys this is serious not only that it will be added to his record as a criminal offence, it will add to his credit rating for non-payment (if not payed by due date). He might even get black listed and won't be able to get any financial loans in the future.
Pay the fine on time, you were in the spot for too long and left the car unattended, so they have no way of knowing that it was overheating (not that they would care), and you won't have any issues.
OK, getting more confused than before so just paid the damn thing. ahhh the beauty of online payment...it doesn't hurt as much as dishing out cold hard earn cash and handing it over the counter, lol, but still there goes my F1 Grand Prix ticket :closedeyes:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
