So last weekend I decided to heighten the front coilovers a bit as it turned out the tyres would rub the underside of the guards on certain occasions. So I took them out, raised them up 5mm and bam; problem solved. After doing a test drive I noticed a variety of clunks and occasional noises and now I'm unsure if they have been there all along and I didn't notice as I always run the stereo, or is it to do with the work I just did. I don't believe it to be related to the past weekend work as it was a simple enough process and I put it all back together tightly.
Even more confusing is that most of the suspension related parts are in good condition or relatively new. A quick run down...
coilovers - around 15,000kms
front sway bar - aftermarket, new polyurethane bushes 700kms ago
swaybar links- 1300kms old
tension rods - solid, 8,000kms
steering ends - solid, 8,000kms
LCA - standard
tower brace
I know that a set up like this is conducive to NVH but this is something else.
The clunks seem to happen at lower speeds and usually when I'm just minding my business going in a straight line. Its not set off by any specific road conditions or driver inputs. The vibration of the clunk I can even sense through my feet, but I think its coming from both sides. Also there is one from the right rear of the car sometimes too.
I did jack each corner of the car up and did a basic check to see if there was any play in the ball joints, but they seem ok. I did notice about an inch of sideways play in the front wheels, equally on both sides, and put this down to normal play in the L/R motion of the steering system (would that be right?)
So yeah, I'm kinda concerned as I feel like I have the obvious stuff covered, but that said I don't have much confidence in tracking down these clunks. Has this happened to you? What was it? or what have I overlooked?
Thanks!
It could be anything really. I have a clunk that only appears in the wet and its from the Diff bushes. I noticed it after I did all 4 diff bushes and we got a bit of rain, it disappears when it dries out
I know its not much help but just shows it could be anything, even if you have replaced it with something new. Because you think its not a new problem since the coilovers it makes it a bit harder. The Coilover bolts/nuts are all done up nice and tight? coilover bottom mounts on the right way? (They do only go one way, but usually they wont fit the other anyway)
Sorry its not much help
yeah, other threads seem to suggest a variety of things. I guess if it moves, it can make noise. Im wondering if it could be the swaybar touching the control arm, but that's a long shot too. Im hoping for a magic bullet solution, but don't think I'll find one.
have you checked your ashtray for earings??
I have a clunk in my ute...drove me nuts for a few days I thought something was seriously broken in my suspension or something...
well as it turns out
the cable has come off my guard side indicator and it the plug knocks against firewall as i drive...i can feel it through my footwell and it sounds horrible ,clunk clunk, clunk, but now I know its nothing...I ignore it ;)
I chased a noise for ages, had a weird noise from the front of the car. Checked everything and couldnt find a thing
Then one day with the car over a pit, I noticed that for some reason there is a bracket on each front hub that holds the brake line and both had no bolt in them. These had been hitting against the hub. Funny how I never noticed it the first time I looked
Do you have access to a pit? Put it over there and carefully try and take off with the handbrake/brake on to try and put some load on everything while someone stands under the car and looks/listens for noises
Be careful obviously
UPDATE
So I got the front end on stands and got in there to see what I could find. I was half way through fitting standard front suspension as a test when I noticed some movement in the swaybar. it turns out that the swaybar links I bought were a combination of a little loose and a little ill-fitting. I taped the thread (for where it goes through the hole in the swaybar so as to eliminate any play), and also added a washer to all connecting points with a nut, then tightened them all up solid.
I also noticed a little more play than I would like with the tie rod ends where they link up with the knuckle, so I tightened this up a bit more too.
Then went for a test drive and, yey, clunking noises are gone!!
Just an occasional clunk at the rear to follow up. Some other day.
Good to hear you found something.
Sway bar links are a common culprit, usually noticed going in & out of driveways.
Was going to say an inch of sideways play in steering is no good, there should be zero play. That much play will chew out tyres big time!
Yeah, im going to keep an eye on it all though. Tyres are fine, and I put it down to also being off the ground when I checked.
In other news, I was looking at the many underbody pics I took yesterday while there and noticed a turbo dump pipe bolt hanging on right at the end of the thread. Great I saw it and can act on it before it falls right off, but sucks as it means I gotta get out and under the damn car again today...
Unsurprisingly, got under the back of the car and the driver side rear swaybar link has a bit of a creak in it when you move it about (same location as the noise when I drive) so that might well be the cause of that noise too.
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
