Just wondering if anyone knows how to rescale the map sensor on PFCs? Can this be done through datalogit?
here's the background story
My HC boost reading is -260mmHg when the engine's off (0mmHg), sensor output shows 1.5v on the HC which I gathered its correct after having done a search online and read through Paul's PFC guide
at Idle it shows -560mmHg which is pretty much right.
at stock boost level 7psi-ish, the HC shows near 0mmHg
I have also tried two sensors- both does the same thing, also tried to reset the PFC via HC and whilst it has reset everything else, it hasn't helped with the boost reading
I believe the map sensor is operational but the scaling was adjusted by previous owner of the PFC (if this can be done), god knows how many owners it has gone through.
have read through paul's PFC guide, although it does have reference to rescaling the map sensor but looks like the information is for djetro PFCs
You cannot re-scale the MAP sensor, if its giving you false readings then there is either a problem with the MAP sensor, the wiring, or the Power FC itself.
If you have tried a different MAP sensor then it is unlikely to be that (are you using the right one?)
So that leaves either a wiring issue or an internal Power FC problem
Easy enough to check the wiring, put a meter from one end to the other checking for minimal resistance between each end of the wire
If this fails it may be a problem with the Power FC
I take it you have checked the connections to the MAP sensor? It would be a bit odd for there to be something causing this with the car off, but might pay to unplug the boost feed to the sensor and just hold it in free air. You could also check nothing is stuck in the map sensor inlet but I would be very suprised if this was the problem
Yup thank you that helped a lot
The map sensor is from kando dynamics, tried two sensors and both have the same issue
I do have a genuine apexi one on the way, but it's probably a week away
The wiring harness is new so I doubt it's that.
I have a blitz turbo timer with built in boost gauge which feeds off the same line (stock boost gauge source) and they all read correctly
Guess I'll just patiently wait for my apexi sensor to arrive and hope for the best
yeah i think you need the apexi sensor or you will have issues. Because you cant tell it what sensor you are using (on the boost control side anyway), it will assume its the apexi sensor. So anything different to that will not work properly
The kando dynamics map sensor actually looked almost exactly the same as the apexi and having checked with the seller he claims it will work with PFC, avcr and emanage
I've got the new genuine apexi one in the post today so I will put that on later and see how that goes
Cheers
looks like I've got the wrong map sensor- tried the genuine apexi one and that is still doing the same thing
the one I bought is the same as the AVCR- had AVCR in my old car and I just assumed that its the same as the one in power fc boost controller kit
here's the link
http://www.ebay.com.au/itm/121263887995
Is this the correct one for PFC boost controller? PN: 949940-6270, denso 3 bar- seems to be the same as the one used in Djetro PFCs
http://www.ebay.com.au/itm/APEXi-Power-FC-Djetro-3bar-Map-Sensor-x-1-499-x001-/181162935162
Edited by chiksluvit
I can conclude that AVCR sensor is different compared to the PFC map sensor, had the wrong sensor so that's what was causing the boost numbers to not read right on the hand controller
Got another map sensor on it and it's now showing the right boost levels, verified against the blitz boost gauge
for anyone who's interested, the apexi denso one cost around $2~300, GM 3 bar sensor works but price varies and you'll need to do some soldering to fit the plug, so I thought I'd give this $40 no brand generic sensor a go and it was pretty spot on, been on the car for a few days now and it works fine
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
