Hi Guys,
I am having some custom gauges made up to suit an R33 RB26DETT engine, I want to get Yellow and Red permanent warning marks put on the gauges to match the style of the existing gauges.
I am not quite sure where i would find this information, so putting it out there for the common consensus!
What would be consistent Warning and Danger levels for the following sensors:
Water Temperature (degrees Celsius)
Oil Temperature (degrees Celsius)
Oil Pressure (PSI)
Thanks guys, appreciate the feedback
Nobody ? :)
from general research i can't find any definitive answers, do the following sound safe?
Water Temp - 90'
Oil Temp - 115' or 130'?
Oil pressure - this one seems hard to find, low pressure warning should be around 20PSI?
  • 3 weeks later...
Didn't want to start a new thread. So I picked up one of the old school greddy electronic oil pressure gauges, it has a warning setting but I've got a feeling it's going to be for excessive oil pressure rather than low oil pressure. Meaning that if I set the warning for 1-2 bar it's going to have the light on whenever it's over that.
Anyone know?
Yeah you would think so, it's just that I already have the boost and temp gauges from ten years ago and the way u set them is to move the needle to where u want the warning light to come on and if the guage reads over that, on comes the warning light.
However if I set the gauge at say 1-2 bar( it reads to about 10 bar) then anything over 1-2 bar will see the light come on, which is the opposite to what I obviously want. I may just have to install it and see
