When i accelerate at the green lights after coming to a stop, people around me are always going faster then me and so i compared my rpm to their rpm when accelerating from the green light is they often always rev up to 3300 rpm as this is what it takes for my R34 to keep up with them side by side
I usually rev up and cruise after the start of green lights constantly at 1500 - 2000 rpm because anymore then that my engine feels like its wearing itself out and burning unnecessary fuel as my engine always gives off this whooshing sound after 3000 rpm and roars loudly within the car's cabin. (oh and i usually smell fuel within the car after revving it up to 3000)
Whats weird is that i tested beside cars such as old camrys, corollas, Mazda 3s and 8 etc and they are driven by mature aged people and they drive hard up to 3300 rpm usually.
Yet even after revving it up to 3300 rpm cars behind me still stick close expecting me to go faster even when i'm on the left side of the road.
Oh and i forgot to add, i rev to 2500 rpm and constantly stay there gets me to 40 - 50 km slowly and i mean very slowly like around 6 seconds and that every car overtook me like i'm driving like a grandma.
Edited by Elegant Skyline
Seriously
the engine is most efficient at 7000rpm , so that's where you need to be all the time.
Its why the R34s have tiptronic, you can manually select the gear to get you closest to 7000rpm
When i use my tiptronic i often smell something burning so i don't use it plus i don't want to go over 3000 rpm as it seems too much for me.
Fuel needle drops like a rock when i reach near it.
Even then i stick to the speed limit and keep getting bad fuel economy.
Most efficient?
So i would use up to nearly half my fuel tank just to go the city and back at Liverpool?
I wonder if any tuning will give me better acceleration below the 2500 rpm range but be economical.
22's = more efficient tyres. Just ask the tyre joint for some.
Sounds like you need to remove the stupid mods and get someone to look at the car. Have you checked for boost leaks?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
