I did took it to a mechanic 1 month ago and said the same thing, they said theres nothing wrong with it even using the computer it indicated theres nothing weird at all. I am only aware this car only has spiltfire coils, K&N air filter, turbo timer as i got this car only last year.
Must be my driving i suppose.
Is the place to measure the boost leak in front of the driver near the oil filter that is covered by a small black tip to put a gauge in?
If so the mechanic also measure it with his gauge and it indicated no leaks at all.
3000rpm really shouldn't be causeing issues, especially in a 34. General driving I've found my 33 GTST is most fuel economical driving at 3000-3500rpm marks. My Bluebird is similar story and has no issues going well above the 3000rpm mark both cars have 20yr old never rebuilt engines in them. Odd with the fuel smell etc, my 33 is always fuelie but is in desperate need of a tune. Possibly might not hurt to take it to another mechanic just for the sake of a second opinion.
@ Anfanee: Well i don't really know cause i just got this car last year and it came with it, but i cleaned it 1 month ago using K&N oil filter cleaning kit and it looks how it suppose to.
Edited by Elegant Skyline
I'm going to do a full service soon as it going to hit the 97 000 km mark soon so i'm going to pray its going to feel smooth when i first got this car :)
Rev it hard.
If it blows up it was a shit engine and you didnt want it anyway , unless you do want a shit engine, which would be weird. (But make sense at the same time as this thread is weird)
the biggest problem is you have an oil filter, it restricts the engine and makes it less fuel efficient around the 3300rpm mark
take that pesky thing off and let it free flow, you will gain around 4L of fuel around 100km and increase of around 30whp
#@Elegant Skyline
It will not break the car reving it past 3000rpm when taking off from the lights to keep up with traffic.
So don't worry about that honestly, these engines have had farrrr worse treatment and have been able to handle it.
If you are looking for better fuel economy then maybe start with how much you are currently using.
How many Km would you get from 50L or fuel and we can tell you if it's bad or just a normal skyline.
Then you can start crossing things off the list below and try improve it.
Clean your AFM
Replace your O2 sensor
Check for boost leaks
These are just to name a few things to start with.
If you don't understand what the above are then I suggest doing a search in google or taking the car to a mechanic to get them done.
Cheers
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
