I did took it to a mechanic 1 month ago and said the same thing, they said theres nothing wrong with it even using the computer it indicated theres nothing weird at all. I am only aware this car only has spiltfire coils, K&N air filter, turbo timer as i got this car only last year.
Must be my driving i suppose.
Is the place to measure the boost leak in front of the driver near the oil filter that is covered by a small black tip to put a gauge in?
If so the mechanic also measure it with his gauge and it indicated no leaks at all.
3000rpm really shouldn't be causeing issues, especially in a 34. General driving I've found my 33 GTST is most fuel economical driving at 3000-3500rpm marks. My Bluebird is similar story and has no issues going well above the 3000rpm mark both cars have 20yr old never rebuilt engines in them. Odd with the fuel smell etc, my 33 is always fuelie but is in desperate need of a tune. Possibly might not hurt to take it to another mechanic just for the sake of a second opinion.
@ Anfanee: Well i don't really know cause i just got this car last year and it came with it, but i cleaned it 1 month ago using K&N oil filter cleaning kit and it looks how it suppose to.
Edited by Elegant Skyline
I'm going to do a full service soon as it going to hit the 97 000 km mark soon so i'm going to pray its going to feel smooth when i first got this car :)
Rev it hard.
If it blows up it was a shit engine and you didnt want it anyway , unless you do want a shit engine, which would be weird. (But make sense at the same time as this thread is weird)
the biggest problem is you have an oil filter, it restricts the engine and makes it less fuel efficient around the 3300rpm mark
take that pesky thing off and let it free flow, you will gain around 4L of fuel around 100km and increase of around 30whp
#@Elegant Skyline
It will not break the car reving it past 3000rpm when taking off from the lights to keep up with traffic.
So don't worry about that honestly, these engines have had farrrr worse treatment and have been able to handle it.
If you are looking for better fuel economy then maybe start with how much you are currently using.
How many Km would you get from 50L or fuel and we can tell you if it's bad or just a normal skyline.
Then you can start crossing things off the list below and try improve it.
Clean your AFM
Replace your O2 sensor
Check for boost leaks
These are just to name a few things to start with.
If you don't understand what the above are then I suggest doing a search in google or taking the car to a mechanic to get them done.
Cheers
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
