Hey all,
I've got another issue with my 96 gtst.
Driving along today on about 70k's, aircon on (32 degrees outside), changed to an 80k zone so I go to speed up a little.
All of a sudden I can feel the car rev, but the tacho didn't move. I backed off and tried again. Same thing, but the hicas light came on. Then I lost power steering. The whole dash lit up, all warning lights came on. As I pulled over, she stalled.
I let it sit for 10-15 minutes, tried cranking her over, she would start and idle rough as hell ~450 rpm then stall again. She did that about 3 times but now won't start at all!
Bog stock apart from an exhaust.
2 weeks ago I put a new fuel pump in.
Replaced the fuel filter.
Replaced all spark plugs.
Cleaned the afm.
Checked over all coil pack and the loom - all in mint condition.
I've checked all fuses, nothing is blown, all the relays are good...
I'm stumped!
Anyone else have this happen??
https://www.sau.com.au/forums/topic/440063-r33-gtst-suddenly-died-wont-start/
Sounds like the fuel pump you replaced is having issues, pull off the fuel hose and feed it into a bucket or bottle and flick the car "ON" however don't crank it. It should prime, see if there's any fuel first.
Then work from there
I didn't check by pulling the hose off, but after letting it sit for an hour or so yesterday, I flicked it to 'on' and I could hear the relay click and the pump prime (noisy walbro). I'll pull the hose tonight after work and check for flow.
Will post the results later.
could be anything...loose or cracked vacuum hose, bad maf, bad o2 sensor, loose electrical connection, poor sensor ground, or faulty cam position sensor. Those are the main things that will cause a car to run erratic.
No fuel pressure. Again.
Took the line off the manifold, turned accessories on and nothing. Thought it might have been the filter, so I took that off and still nothing!!
I've tried swapping relays around, tried other fuses but no joy.
This thing is doing my head in...
Fuel pump would be installed incorrectly and hose might have popped off inside the tank, hence you can hear it prime but yet you're getting no fuel pressure.
** edit
OR your FPCM & resistor has carked it.. try earthing your pump directly, bypassing the OEM earth.
This is the part where I put on my little propeller hat and slink away...
This arvo after pulling a fuel line, I run a multimeter over the fuel pump loom and plugs. Good power there. So I pulled out the pump - I should have taken photos, it was so odd - one strand of wire hanging on to the positive wire!! I soldered the joins and heat shrinked them, not knowing heat shrink deteriorates in fuel, but the strangest thing was that it looked like the solder had corroded, it was pitted in spots and missing in others! I know that I had great joins when It went in two weeks ago, so exposed wire and completely covered in solder. Unsure what solder it was as I no longer have the roll...
Has anyone ever seen/heard of this happening??
I had this problem in ethanol. The heatshrink was completely missing on one wire and the solder had deteriorated. Ended up using crimps in the end. I usually don't trust crimps for large currents but if you strip about 15mm off each wire and have them overlapping inside the crimp connector then how bad can they be
did you use chemical resistant heat shrink?
I have.. seems "ok" so far LOL
Phew! I was starting to think I was going loopy!!!
I did put one tank of 100 octane through her.. but it sat for about 3 days with it in there..
As for the heat shrink, I had ni idea it wasn't fuel safe... do now though!
I'll keep you in mind incase I die again Artz! ;)
100 octane what? What % of ethanol did it have?
    • OK, well, in that case, the suspension specialist is either a moron, or you aren't understanding what he was trying to tell you. Nismo arms are not really different than stock arms. Both are fixed geometry. I don't know if the Nismo ones are a little shorter than the stockers (or perhaps even a little longer) or the same length, but....if you swap from stock to Nismo, whatever happens to one side will happen to the other side. It will not cause it to steer left or right. That is unless you have adjustable bushes in your stockers, and they happen to be adjusted to dial out some bent chassis shenanigans. But, if that were the case, you'd just put adjustables in the Nismo arms anyway, because Nismo arms are essentially just expensive stock arms. And doing a wheel alignment is just a weekly thing in my world. I have had the suspension apart so many times this year that I've lost count and just about worn out a torque wrench. I'm out in the shed right now cutting up some alloy section and making bases for my new stringline setup. Got to make new swivel plates next, then I'm good to do toe properly, as well as camber and bump steer.
    • Yeah, nah. Not a thing. The gasket between the top of the plenum and the runners is far more likely to blow out when it gets old, and not really at ~14 psi. These things have been run to double that for 30 years without that being a common thing.
    • I plan to pull the intake manifold off and check the gaskets, i read that the block to manifold gasket can blow over 14psi and when i picked up the car it was set to 1.2bar on the controller. Send the injectors out for cleaning. Ill also pull the cam covers off and do an inspection, check some valve lash. Someone also said that the timing belt can rub or vibrate against the belt cover and make that sound. Definitely need to get an AFR gauge on it, if it was lean idling im sure it wont be happy
    • Well, it is an unusual noise. Use a 2 foot long bit of garden hose stuck in your ear as a stethoscope to pin it down to a definite location. We'll never work it out across the internet.
