after not finding the chassis braces I want, thinking I will just make my own. My understanding is, given an equal diameter and wall thickness, square tube will be stronger and flex less than round tube, is that right?
https://www.sau.com.au/forums/topic/440104-strongest-square-vs-round-tube/
square tube doesn't have a diameter. if you are talking about width/depth to an equivalent diameter, you can just look up the catalogues/tables on websites like onesteel. they provide all the data. "I" for deflection "Z" for bending. higher number = winning.
It's not in bending anyway it's related to area and I value.
square will look shit, if you're talking about strut braces... which I am assuming you are?
Good answer, Jas-25T
Also round will have uniform strength in all directions, whereas square won't This can cause problems in some situations (although not likely to be a major issue in your case)
Shouldn't you be chasing strength vs weight?
Personally I prefer to work with square as it tends to be more flexible from a design/manufacturing point of view in terms of joins, attaching to things, drilled / bolted connections etc., and easier for manufacture. That's only one part of the equation (wearing my manufacturer's hat as opposed to engineer's hat)
Edited by warps
Without looking at the tables I'd think that for a given diameter (side) and thickness, square would be stronger in bending, tension and possibly torsion (though I'm not 100% sure on the last one). It will weigh more though.
for my application and usage the few hundred grams weight difference really isn't going to matter, but on that note the strength difference isn't going to be that massive either it seems.
For bending said tubing, either square or round, is press-bending as opposed to having mandrel bends, likely to be an issue in terms of creating a flex-point in the brace?
Depends on the design and loading. A bent member in compression / tension (as most diagonal braces tend to be) will be much weaker than a straight one (look up Euler column buckling if you want a bit of an education), regardless of the bending method. Again, too many variables to say whether it will have a noticeable effect in your case (without looking at design / proposed loading etc.)
Press bending tends to reduce the section width (y direction), hence the Iyy value will be less, so in theory will be weaker in bending. In practice, this effect may be negligible so not worth worrying about.
  • 3 months later...
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
