after not finding the chassis braces I want, thinking I will just make my own. My understanding is, given an equal diameter and wall thickness, square tube will be stronger and flex less than round tube, is that right?
https://www.sau.com.au/forums/topic/440104-strongest-square-vs-round-tube/
square tube doesn't have a diameter. if you are talking about width/depth to an equivalent diameter, you can just look up the catalogues/tables on websites like onesteel. they provide all the data. "I" for deflection "Z" for bending. higher number = winning.
It's not in bending anyway it's related to area and I value.
square will look shit, if you're talking about strut braces... which I am assuming you are?
Good answer, Jas-25T
Also round will have uniform strength in all directions, whereas square won't This can cause problems in some situations (although not likely to be a major issue in your case)
Shouldn't you be chasing strength vs weight?
Personally I prefer to work with square as it tends to be more flexible from a design/manufacturing point of view in terms of joins, attaching to things, drilled / bolted connections etc., and easier for manufacture. That's only one part of the equation (wearing my manufacturer's hat as opposed to engineer's hat)
Edited by warps
Without looking at the tables I'd think that for a given diameter (side) and thickness, square would be stronger in bending, tension and possibly torsion (though I'm not 100% sure on the last one). It will weigh more though.
for my application and usage the few hundred grams weight difference really isn't going to matter, but on that note the strength difference isn't going to be that massive either it seems.
For bending said tubing, either square or round, is press-bending as opposed to having mandrel bends, likely to be an issue in terms of creating a flex-point in the brace?
Depends on the design and loading. A bent member in compression / tension (as most diagonal braces tend to be) will be much weaker than a straight one (look up Euler column buckling if you want a bit of an education), regardless of the bending method. Again, too many variables to say whether it will have a noticeable effect in your case (without looking at design / proposed loading etc.)
Press bending tends to reduce the section width (y direction), hence the Iyy value will be less, so in theory will be weaker in bending. In practice, this effect may be negligible so not worth worrying about.
  • 3 months later...
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
