  • Replies 83
PLAGARISM!!!! LOL!
fluxeh, you forgot the Fuel System one on the bottom right hand side.
I'm 90% done with the letter decoding, tryin to figure out a table... damn their vertical japanese writing!
OK then put this in the image (and this time use a GIF instead of makin a 1mb JPG :D)
Here's the factory Extras that are indicated by the last 7 characters ona 1989 -1991 R32
VS Sign
Position 1
Blank = Standard Headlight
L = Projector Headlight
Position 2
Blank = Standard
P = Electronic control active Full auto air-conditioner (Climate control system I assume)
Q = Electronic control active Sound System (Upgraded Sound System?)
Z = Cold District Specification
M = P +Q
V = P + Z
W = Q + Z
T = P + Q + Z
Pack Sign
Char	Pos:	1   	 2
A	Standard    Standard
B	4 Wheel Anti Skid (ABS?)  GTR Steering Wheel
C	Sunroof   	 Type M Specification
D	GT Auto Spoiler (Front Only)  Viscous LSD
E	GT Auto Spoiler (Front and Rear)	B + D
F	B + C
G	B + D
H	B + E
I	C + D
J	C + E   	 GTE Special Seat
K	B + C + D    J + Viscous LSD
L	B + C + E
SS 	 V Selection
Position 	 Number: 0	1	2	3	4
1 With ASCD - RB20E RB20DE
  Super HICAS RB20DET 2WD  S	Y  Y
1 Audioless (All Cars) 	 S  Y	Y
2 185/70 tyres + 14 inch rims (CA18i)	S	Y
2 15 Inch Alloy Rims 	 S 	 Y
3 Electric Side Mirrors (CA18i)  S	Y
3 Fender Mirror (All Cars)  S  Y  Y
3 Rear Wiper    S 	 Y	Y
S = Standard (ie. does not apply) Y = Vehicle is equipped with this
Well Alpha Version 2 of Funkeys Translation is now finished.
Please note this is for viewing purpose only, it if not the final product and information MAY BE INCORRECT.
So please wait till the final copy if released, which should be some time in the next 7 days. As I have to wait for Funkey Monkeys translation, then I have to doubble check it to see if we both agree information is correct. Then I need to draw up the english version, which takes soem time as well.
Having Said that, a big Thank you to funkeymonkey for taken the time to provide everyone with this information. :)
Gatty - I am unsure what you are asking.
If you have a copy of 'Nissan FAST Software' then you can 'put your VIN in' that program.
If you do not have a copy of this software (not many people do.) Then to find out the breakdown of your vin number, you simply need to follow the charts provided by FunkeyMonkey (and myself). However please note that this charts are currently not finalized.
The finalized translated versions will hopefully be released within the week.
See how the curly brackets go into VS"something" and then the next two go into box and then the next 3 go into the box?
Well Pack Sign is sorta like "Package Extras Sign" I guess its all the extras that come with the car. The direct translation of it is Pack Sign, which is what I put there, coz I haven't done the rest of the translation, which will tell me what it is.
For now mark the Options Categoris as "VS Options", "Package Options", Personal Options" if it makes it any easier to understand
10-4 On that Funkey :D
I will Edit that one, and ill start the 89 - 91 tonight.
I took a shot a translating the text at the very top of the picture.
Correct me if im wrong, but I think the Kanji translation means..
2.2 Moderu moderu nanpaa puruu tono kanji ru kanji
janji no kanji ridesu
Does that sound like something?
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
