Decoding The Skyline Model Code
Well here we are again :D
Tonight has been a busy night for me, so I havnt had a chance to finish off any of the tables.pictures whatever you wanna call them.
This is currently what is dont on the R32 89 - 91 Chart. The Areas in Red I need you to Translate for me (FunkeyMunkey) :D.
I think the text in the lower half of the chart is the same word for word?
After looking at your break down of the 'Extras table" (also in the second half of the pic) The way I read it it..
L - Means look in the First column of the 'Vs Sign' Table to find out what That letter represents?
M - Means look in the Second column of the 'Vs Sign' Table to find out what That letter represents?
A - Means look in the First column of the 'Pack Sign' Table to find out what That letter represents?
B - Means look in the Second column of the 'Pack Sign' Table to find out what That letter represents?
0 - Means look in the First column of the 'Personal Sign' Table to find out what That Number represents?
3 - Means look in the Second column of the 'Personal Sign' Table to find out what That Number represents?
0 - Means look in the Second column of the 'Personal Sign' Table to find out what That Number represents?
Am i on the right track?
  • Replies 83
Close lol, those letters are just examples. But yeah the positions they occupy is what you should be looking at.
it means that yours are all blanks... check my decoding list for the options... there's blanks in there as well which means your car was as stock as they came. R32 series 2 were different tho, stay tuned for the decoding guide for htat.
Guest two.06l
Funkey - AWsome, yeah i know they were Examples .. I just couldnt really explain what I was trying to say. :cheers:
the ultimate test BNR32-300885
  • 4 months later...
Been playing with fast.. interesting program, I have to say that Honda's one is much better..
Anyway, I was trying to decode my model code
KBNR32RXFSLMZG
It's all sweet thanks to you guys right up to the ZG part, which i can find in screen 7/27 of the Model 1-13 digits option code list.. could anyone help me out translating this?
Thanks,
-Patrick
  • 1 month later...
Just purchased an r32 coupe.. has a goddy steering wheel as standard..
E-HCR32
HCR32-086661
KRCR32RGFELMSF
TH1 G
FS5W71C RC43
From what i've been reading.. it has a godzilla steering wheel and viscious lsd as standard?
  • 2 months later...
BGKBRTAR34UDA-FB-A
B= 4 door sedan
GK=RB25DET
B=2 wheel drive
R=?
T=GTT
A= 4 speed auto
R34= I wonder :D
U= forced induction?
D=?
A=?
-= no option
F=?
B=?
-= no option
A=?
Apparently, my car has TV navigation, tinted windows, bodkit options not sure how it fits into this schema. Has ABS but think thats standard.
This is what fast spits out.
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
Model : R33
Prod Month/Year: 12/93
color : QM1
INterior : K
Rb25DET, HICAS., RWD, 5-Spd
Model code: GGKBRTFR33VDAA--AB
And if anyone knows is KH2 Gunmetal Grey?
Sorry about the posting to old threads, but I was just searching for some info on color codes and noticed noone replied to the guy before me.
  • 2 months later...
can anyone run this number for me
ECR33-060296
and with the color code KN6 K , can you tell me what the interior color "K" is supposed to be?
also, can you tell me what factory options it lists?
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
