$1000? Hpi dumps are $520 plus delivery from Nengun.
I'd say you couldn't find anything because when pushing for such high numbers with low mounts you'll be needing everything in your favour. How much of a difference they will make, NFI.
Summary of above:
Will they flow that much? Probably not.
Making 450kw from low mounts? You would hope you have every possible supporting mod to get you the best result you can, because you are asking for every last fraction of a HP.
thread/
setup im thinking of putting together.
built 26
-5s
270 cams/springs
port matched manifolds
3in front pipes, decat 4in exhaust
realistically that setup will be closer to 400, but want a 450 buffer, who knows, it might take 25/26 pounds then be closer to 450..
been chatting with a shop (overseas) who does allot of 800 horse twin GTX setups, he tells me the 34 dumps would flow that power, when asked the benafit of the larger hpi dumps, he says, turbo spools a little earlier
built 26
-5s
270 cams/springs
Care up share more info on the big power low mount Gtx combinations?
It's a a street car, so it will spend allot of time "flexing" larger cam/lumpy idle is a must:) even if it mean a little less response
Got a vid of those Unigroup cams on idle
http://s1068.photobucket.com/user/Ptriffitt/media/E42612E0-0E51-4A33-99C7-841C9B0DF39B-27312-00000BD0E9B48A81_zps3606a788.mp4.html
I don't have the car at home ATM but these are on E85. I specifically asked for the idle to be calm as we could get it. If I wanted it grumpy then it's just a few taps on the keyboard. On petrol it's grumpy as hell!
There is a bit of info and a few graphs up on here recently if you have a search. I helped with a 500kw twin GTX combo running factory airbox, manifolds and cooler/piping, so there is definitely more to be made if you don't mind a defect.
In your opinion, what do you think the factory airbox is worth at that sort of power level? I've always wanted to do a back to back with a set of pods.
  • Like 1
With the filter and lid dropped it made 20kw more, so there is a little in it with a good twin pod setup. (as long as they get cold air)
We don't get much of an option down here, the customer wanted it to look factory if he was pulled over, so it was a great result for him.
What car/ airbox was that ?
I'm hoping for that or close to it with the R34 box
    • Ha! well, there's your problem!  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the “pssshhhh” back when I open the fuel cap 😂🙌🏼🙌🏼 It was 100% the O ring because that bloody thing was inside the fuel tank 😂😂😂😂😂 Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❤️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
