So basically i have read through the suspension thread and found out that I need r33/34 upper camber arms for the front. My question is which style should i be opting for?
-a. The one piece design (like factory and cusco) which to me doesn't seem to give much flexibility in the adjustment (5mm increments) or
-b. The two piece design with one straight arm and one curved arm that appear to have infinite increments of adjustment (by screwing in or out as needed) Though i have read the curved one can be a pain to adjust, though no specific reason was given as to why.
Also background info. 1999 c34 rs4 converted to manual. currently running whiteline eccentric/concentric? bushes which haven't given me enough correction to fix the camber issue i have.
was hoping to use hardrace brand arms throughout the car (already have them in the rear) but as yet they don't make a kit for r33/34/stagea and i'm sick of shelling out for new tyres so not waiting for them to finish developing them. After doing some searching around i have been left with the above conundrum.
Any thoughts??
https://www.sau.com.au/forums/topic/440129-suspension-which-front-camber-arm/
Cusco are stronger. I had a set which gave me 3 deg neg on maximum setting. (ideal for track/slicks - 1 deg would be plenty for street use.) I took them out as they wore my street tyres too much and I didn't want to pay for an alignment before and after each track day. I now have the adjustable bushes which give me about 1.5 neg.
What is the issue that you have which you are trying to fix?
Currently sitting at 2.0 neg with full out on the bushes which is wearing out tyres way to quickly. I think there may be other issues at play as well (suspected accident before I got it) but camber is definately contributing to the problem and is (I thought) the easisest to correct.
As i say my issue with the cusco's is the apparent lack of adjustability, unless I am missing something about the way they work. I am definately NOT a suspension wizz haha
If i got the cusco's can i use the current whiteline bushes to do the fine tuning after getting it roughly right with the arm? AFAIK though I don't get 5mm adjustment out of the bush so there would still be a 'dead spot' where i can't get the camber to sit.
it is a fairly low car, not ridiculous but i imagine it is another contributing factor, hard for me to measure arch to center as i have no flat surface to park it (lives on the road, single garage is used as storage due to small unit, all complex driveways are cambered to the centre to allow for drainage).
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
