Curiousity really, see if there is any possible benefit or if it is just a waste of time. I dont have much interest in chasing power or changing the stock setup past removing restrictions, so shit like this is my Niche.
Plus love to prove the "bandwagoners" who comment alot and know very little.
It's a waste of time, if you're shit keen on it buy an aftermarket ECU and tune it on E10 - the cheap shit (not P100 E10)
Your car will run shit, your economy will be shit.. essentially you're running less timing to compensate for this fuel, which is usually inconsistent too.
E10 is made for lawn mowers and whipper snippers
Most probably will be the case.
if you're tight, just run 95 RON - get toshi to remap your stock rich as fek ECU and happy days.. more economy, more drivability - done.
Ahh.. E10 will make more power. Not less. E10 is a better burning fuel and that's why it is used in all new cars. Ask the police about their f6 and gts. They will tell you the same thing.
Yeh actually I think you will find that E10 is part of a government initiative to push renewable fuel sources. Clever marketing campaigns to promote the stuff make it sound like it turns Excels into top fuel dragsters, in reality it is a lower octane fuel and will make less power. It is a fuel designed to reduce our fossil fuel usage and lower our carbon footprint, nothing else.
E85 on the other hand, that's sorcery and witchcraft in a bottle :devil:
P.S Woot, first post here in months :laugh:
E10 is better than E85. You've obviously fallen into the trap of the great marketing generated by the distributors of E85. Now I'm not calling you an idiot, please don't take offense to my post.
It's the same as when someone was saying a lower comp engine is better for turbo, when in reality and high comp engine will make more power and is naturally stronger. Often in trade we call them a low 'strength' engine and high strength. This has been covered before.
  • Like 1
"Unleaded E10 is United Petroleums ethanol-based unleaded petrol offering. As a result of ethanol being present, it has an octane rating of 95; higher than the 91 octane of normal unleaded petrol. Ethanol is a natural octane enhancer - adding ethanol to petrol boosts the octane number and its performance. It also helps the other components in petrol burn more completely thereby having a cleaning effect on a cars fuel system."
Off United's site.
How can E10 be 91 RON when the base is 91 RON then blended with a higher (ethanol) product?
good to see not everyone is a simpleton :thumbsup:
So a 91 or 95 octane fuel (E10) is better then a 105 octane fuel (E85)?
Whatever the case is with the RON of E10, I think there is no doubt they wont be using their 'best of the batch' 91 octane fuel in it
E10 is not better. If you think its better, why arent you putting it in your car? go and do it, tell me how that goes. I've used it in N/A Cars and performance and economy both suffered.
Edited by 89CAL
Lol. My giggle for the day is complete. This thread can now move to the wasteland for further lulz.
I just hope he doesn't think you are serious Tom. :P
  • Like 1
Seems it fooled me? lol................... :S
Seeing that E85 is blended with 91 at the bowser, would they be blending that with "not their best batch" also?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
