For sale is my EVO VI - family commitments mean I need to let her go.
Putting my 250kw atw's on a safe tune
Basics are cosworth cams
Greddy td06 25g. turbo and Greddy manifold. with internal gate
Varex remote control exhaust. very loud or quiet...
Teins fully adjustable coilovers.
Meek intercooler piping and custom pipe work for greddy td06.
Volk ce28s wrapped in near new rubber.
Apexi power fc with hand controller.
Ralliart front and rear braces.
Hks ssqv bov and Hks mushroom filter inside custom airbox.
1000cc injectors.
Greddy boost controller and turbo timer.
Evo 8 mr flywheel and organic clutch
Serviced every 5k at toyko motorsport around $30k in receipts in the last few years.
Sunroof model very very rare!!
Done 147k but head rebuilt 20k ish ago new timing belt/water pump tensioners etc
Engine is super strong no issues at all, has organic clutch with evo 8 flywheel.
New rotors and pads front and back.
Interior is like new.
Never ever been in any accidents or had panel damage, paint etc all original paint and panels.
No oil leaks odd noises etc performs as it should and has been extremely well looked after by 2 mature owners and only used for the shows and weekend use.
All electrics work perfect air con is nice and cold
Car made 250kw's at all 4 wheels on low boost setting 1.2bar.
Drives really nice and tight and it definitely has had a easy life and been pampered I have a stack of paperwork for lots of work done.
This is 100% one of the better ones for sale go look at the rest then come check this out you wont be disappointed
https://www.sau.com.au/forums/topic/440164-mitsubishi-evo-vi-for-sale-20k/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
