Hello there,
My first post and I need some help. I did use search but didn't find anything I could use.
The car is 1991 R32 GTR.
My clutch pedal is very stiff. I have almost no clutch play - it grabs in a very close distance - feels like on/off switch. I am looking for the ways to make my clutch pedal more forgiving. What would be the suggestions?
Previous owner wasn't sure but told me that it's most likely Exedy (?) twin plate clutch. Any way to identify the clutch without dropping the tranny?
I downloaded the R32 GTR service manual and will try to trace and check the system for leaks and whatnot. I don't know what lines I have - nismo or oem, I am not sure if any other components are oem or replaced (master cylinder, operating cylinder, what fluid used, clutch booster oem or a/m? etc.) So additional question would be what to look for and how to identify the major oem or a/m components.
I would appreciate any help I can get.
https://www.sau.com.au/forums/topic/440182-help-with-stiff-clutch-needed/
Stiff clutches are the bomb.
1 easy way. Go to gym, do bulk squats.
Clutch pedal will feel like your bitch
Solid advice. Appreciate it. As you may know gym results may take time to take effect. What would you suggest I do in meanwhile as far as clutch adjustments go?
AFAIK you can't tell whats in there without dropping the box. Unless maybe you can see through the clutch fork hole a bit?
Check you have vacuum at the clutch booster (works the same way as a brake booster). If you clutch in and start the motor you should feel it in the pedal.
For the take up point, there should be an adjustment at the pedal (i've never need to adjust mine, so have never checked it out myself). I have the NPC 250mm organic, and its like a factory clutch - super easy to use with 300kw. I dont think it would last long under abuse tho (clutch dumps).
  • Like 1
Thank you I will check the booster operation and will play with pedal settings. Hope it will make the difference.
I messaged the owner again and he checked the info with the guy who sold the car to him. So the clutch I have is Exedy stage 3 hyper single 6-pack clutch/flywheel combo. He also mentioned that I have oem lines and oem slave cylinder. Well, I will try to play with adjustments as you suggested (also thank you so much for everybody who pm'ed me!) and if adjustments won't work, I just will exchange the clutch for something more forgiving. This car will not see the track and sitting in the traffic with this clutch is unbearable...
As for one leg buff - I don't think my husband will appreciate this type of the body upgrades haha :P
Do they R32 GTR run a 3/4" slave cylinder the same as RB25DET gearboxes?
You could try a bigger bore slave cylinder, Nismo make a 7/8" from memory.
To replace only slave won't give me anything since I still have oem upstream. But! If I replace the whole upstream with bigger bore master, slave and pipes diameter, then I can keep the clutch. The clutch is a quality piece (from my research today) and Id rather keep it. Also saves me the trouble dropping the tranny.
So, that being said, what would be the suggestions for master cylinder, lines and slave cylinder upgrades? What brand would you recommend? What maximum size of everything I can put there? I still am gonna check the system as you guys suggested above but I really thinking now to replace the whole shebam and be done with it. Thoughts?
Edited by Skyride
Replacing the slave to a larger one as suggested improves the mechanical advantage and will make it easier to push the pedal.
It's science.
But I wonder if you keep the master and the lines the same size as before - where the volume will come from? Sorry, I am not very bright :P
Edited by Skyride
It's the ratio between the surface area of the master to the slave that makes it easier (or harder) to push.
Say if the master is half the area of the slave it's twice as easy to push than both being the same size.
You don't need to change lines to get the advantage.
The nismo slave is larger for this reason.
The vac pump on the booster wouldn't help.
  • Like 1
Sorry, I didnt mean to upset you. I just trying to learn. I got what you said in your post above.
Back to books :)
The 7/8'' would be the go.
What setup is your 6 pucker? Ceramic or brass button? What type of center is it running?
This is a contributing factor to clutch engagement.
Is it a new clutch? How many k's has it done?
If its fairly newish, & the adjustment is good, maybe it could do with a MEDIUM/CONTROLLED launch or two to change the friction point.
After my 500k run in on my NPC single organic (re-stickered Exedy GTR setup) clutch I performed 2 medium launches (my Stagea is FAIRLY stock) & it changed the feel & friction point.
  • Like 1
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
