Perhaps it is just that Im a ham fisted monkey, but, I have been having trouble with the 3/4 cluster in my R33 gtst box. I find that the 3 tin clips that hold the selector dog fold the ends off if they get rushed. Then soon after they fall out and the dog doesnt mesh onto the syncro or gear making the shift clunky/grindy as all get out. Most other boxes have a solid blocker system, like the setup in the 1-2 cluster and is much more robust.
Initially the tripple plate clutch was swapped out for a good single to reduce drag on the input shaft, which helped, but now that I'm giving the GT3's a hurry up at Morgan Park, I am pushing through the gears and tending to stress these clips and having to replace them every meeting.
How do you guys fair with the clips?
What did the old group A 32's do? They have the same gear set, we have actually have a 32 gtr gear set in at the moment. It was a cheeper option for a spare set on rotation.
https://www.sau.com.au/forums/topic/440189-gearbox-mods-for-racing/
We have added an extra guide to the 3/4 selector fork, the thought is that the selector dog isn't supported propperly and can fall over. The extra guide might help maintain it in an upright position and take some of the load off the 3 clips. We will get this set back toghther and test it out at Lakeside this weekend.
Edited by Noddy
That's a good idea, interested in how this develops - the SR20 box has the same issue too. I'll have a look when I'm in the workshop tomorrow but perhaps there's a way of going to some sort of spring and key in the hub, rather than the clip arrangement (I can't quite picture the setup at the moment)? I know it would be a bit of machining but may be worth it if it's a recurring issue.
There is a few people Ive spoken to in the last few days who have done similar things with good results. Tig welding extra material in at the top, machining it back to make a slipper pad has been a suggestion too.
I spoke to a guy who worked on the groupA 32's, They used hollinger inturnals. We spoke to Hollinger not long ago about getting some gearsets made up for the Nc RX2's we run (Hollinger used to make them a few years back) but, they were not interested... unless we were going to order 1000 sets. I fear that the gtr stuff will be in the same basket.
lol, and nissan are out of the stupid clips and 3/4 syncros....
because you've personally killed them all!
sorry I am no gearbox expert but with the GTR box I do know there were changes for the last series (series 3 r33), and that the old design was made obsolete. Since the internals are similar/the same are there any series 3 changes you can apply to your box?
BTW great to hear the old girl is still hustling around tracks nicely :)
yep, She has had 2 years sitting in the corner. I picked up a levin on my last trip to Japan and, it has distracted me for a little while. There is a new motor in the pipeline, a pretty silly 26/30. It's all together on the engine stand ready to go in the front cut that came off the black 33 (from the aust titles) for a fit out for a custom dry sump, mounts, piping etc. Then Ill just swap it into the yellow 1. You have to race at Lakeside some day. It'll blow your socks off Duncan.
The changes made worked well at lakeside: however, I was in 4th and 5th for most of the lap there so whasn't much of a work load for the hub. The only time I had an issue was on a down shift when I messed the double clutch up with out enough revs.
  • 3 weeks later...
Have a look at upgrading to an R34 3/4 synchro/sliding hub setup, they use solid type key.
D22 navara's also use some of the same gear just under different numbers, but it is hit and miss with the models
  • 3 weeks later...
General question for those doing track days in R32/R33 GTR's... what gearboxes are you running and power are you racing with?
I am looking at some options at the moment; the OS Gearset seems to be the most cost effective with the 1-5 kit, billet shaft and billet plate totalling just over $3.3k... but I am not sure how many people are racing with them?
Anything after that like a PPG well you can multiply by x3 just to get a gearset without a billet shaft.
I am starting to think just be gentle with the stock one and put the pennies away.
  • 8 months later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
