I'd reckon 6th gear in the Tremec would be pretty much redundant for track use. Ratio selection/spread for 1-2-3 looks to be an improvement. Torque-load capacity obviously is a plus, so the things that I'd like to know is
1. how it handles quick-ish changes at high engine speeds
2. whether this box has its own selection of little components that fail like those little spring clips in the R33 box
3. how difficult/expensive is it to give a Tremec a freshen up if bits do get tired
4. how difficult/expensive is it to engineer a Tremec into a R chassis
Not being negative, and I appreciate that Stuart is having a go at building a better package within a sane budget. Mostly I want to know if it's the sort of upgrade I would want to do. :)
Hey noddy, the issue u were having with the rb25 box failing, was it typically going up the gears ie from 3rd into 4th or going down the gears from 4th to 3rd when it would fail? Thanks
What does the initial damage? Probably a miss shift up to third. There is an awesome technical little track in Stanhope that is all 2nd and third gear. Twice over the last 10 years I've come away snicketty from there where I know I rushed the up shift and forced it in. At morgan park and lakeside on a down change to 4th a similar problem where I didn't get a big enough blip in and rushed the synchros.
Putting the third brass guide at the top definitely helped. We replaced the side ones too, they are pretty wrecked in most of the boxes we see. post-15176-14237442983836_thumb.jpg
Why go to a T56? Well, my gearbox guy did all the development work for MallWood and has had a lot of experience with them. They normally have a number of Teflon parts that he has replaced with various metals. He has a few tricks up his sleeve that have gone into this box.
The other major factor was that I was so over the 25 box. A bit over 12 months ago I sourced a late model (2000) 34 box and gave it all the things we have learnt over the last 8 or so years. 1st meeting of 2014, ttt weekend at morgan park, Saturday was just cruising through the gears beading it in. Sunday, 1st run 2nd lap up to 4th nice and easy.... crunch, and got worse every lap. The dogs on 4th were chewed to hell. Went hunting for parts and ended up with brand new 4th gear and selector hub.
Shared the car at a mate who has been racing since the late 60's. I was racing he was doing a super sprint. We bedded the box in Friday practice and it felt really good. After the 2nd round on Sunday... bag of dicks. Some how bruce killed it.
Went hunting and found a nice 32 GTR box to use, gave it all the tricks and raced at the lakeside classic. No practice so panzied through qually to bed it in. The race meeting went well, no issues, but I just didn't like the feel of it. Didn't touch the car again until the end of the year for a sponsor ride day at QR. It was fine.
I spent the year racing my TRD Japan built AE86 and building a new motor for the 33. The new 30-26 should push a bucket load of torque. 9.2:1 comp, 1 mm oversize valves 88mm pistions 256/272 big lift cams with trust manifold and a pair of TD05's. What is going to stand up to the grunt, handle the race track and fit the budget?
Edited by Noddy
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
