With a search wielding no definitive answer, a new topic it is...
All my other manual cars over the years have idled around 650. All of these cars have been na btw. Even the charger (auto) in park idles at 800..
My s2 stagea rs4s idles when warm at 850-900 rpm. Is this normal or is it too high? (Under the bonnet on the leading edge there's a sticker that says 650) so theres conflicting info already.. is it something to do with turbo and needing to idle higher maybe? How do I adjust it.. if I need to?
Edited by staglover
https://www.sau.com.au/forums/topic/440194-c34-rs4s-idle-speed/
900 sounds too high. Have you tried cleaning the AAC valve? That in itself wont set the idle but there is a screw on there which may be letting in too much air at idle. That screw can be adjusted to bring down the revs. Cant remember the exact idle speed off the top of my head, but I believe the auto idle is slightly higher. 700-750 is what mine is around.
From memory, logging the timing using a consult cable is also a way of seeing if the ecu is trying to regulate too much air entering the engine at idle. If you see the timing fluctuating that may be a problem. Ill have to dig out my old ecu logs.
Thanks for the replys guys. Stock ecu as far as I know.. ive had the car 3 weeks or so from japan and its been at 900rpm since. Runs nice but I always thought it had been a little high.. please excuse my ignorance but what is an AAC valve and where is it located? I thought about adjusting the idle control screw but wasn't sure if that would throw out anything else.. bah ecu's lol
Edited by staglover
http://www.skylinesaustralia.com/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
