I don't mean to be rude, but do you really need a translation? It is just a a relay to overcome any voltage drop that maybe present in the standard wiring. Power going in via a fusible link (red), earth (black), signal wire in (red), signal wire out (blue) .It even shows you the exact signal wire to cut and how to wire it in. Again, I'm only trying to help, but if this is over your head I'd suggest taking the car to an auto electrician.
Most of it I know how to wire up there was just afew thing's I wanted to be 100% sure it was the right spot.
The only thing now is in the 1st photo the thick blue earth cable does that need to go anywhere in particular or can I put it anywhere in the engine bay as the ground? cause in the picture it looks like it go's anywhere on the passager side of the car.
I'll give it ago tomorrow and thanks for your help Tim
I got your PM. Tim's right it just says to fit the earthing wire securely to the body etc. It doesn't give a specific mounting position.
I Installed the Do-Luck Ignition Harness Today all went smooth and here are the results.
Results:
When I started the car up the exhaust tone changed and then I gave it a few revs 3000- 4000 rpm and it wasn’t backfire anymore. Next I took it for a 15min drive up to 7000 rpm and it wasn’t backfiring under boost as it did sometimes.
More testing is required to see if it has removed the under 3000 rpm Miss problem and Backfiring under boost problem completely.
I will keep everyone posted on further result’s but so far I’m happy with the Result.
Note: I have made a "How To" on how to do it. This should be in the DIY section of the forum soon.
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
