Lol I only sent that to MickO a few minutes before you posted it, hive mind?
If the EFR is too big, there is always this recent release: It's only a little T3 turbo - how bad could it be?
Test pilots required for the new Garrett range...with money and patience?
The pro S is getting old mate i think its time you were a guinea pig ;)
I tried the GTX3071R maybe its time you ordered a GTW3071?
.... internally gated GTX29 series.... see why I mentioned Disco..... ;)
Not sure wtf the GTX2871R is about, assuming they will do a GTX2971R.
Damn. Sounds like the GTX29 may have been a good fit for me.
Will be interested to see results when they come out.
Anymore info on any of the new Garrett GTW range Lith? Cant seem to find a actual list any where on it. When are they going to be available to the general public I wonder?
Try searching for GTW3684R or GTW3884R ;) I'm not sure on all the specifics of what is coming out, but they should start emergying pretty soon, as far as I know... it's certainly not going to be like the EFRs!
So tired ATM , too tired to search propeller head stuff but yeah I noticed the 9 bladed compressors and thought hmm HTAish .
Now that Garrett are into machined wheels they can carve all sorts of things up easily enough but it would be good to see a few more modern turbines in their mix .
Other players in the aftermarket have put up things that are easily better than some Garrett products and maybe market pressure has got them off their butts .
Have to love the WWW for showing up the good the bad and the ugly .
A .
  • 9 months later...
A quick update cause I couldn't be stuffed looking for the E70 tuning thread .
I went back from my United E85 (Green)/7Eleven 98ULP 50 50 blend (E42) to Caltex E70 cause I got fed up hand blending all the time .
Laziness just reset the main fuel trim because my timing maps work pretty well overall . The headlines is I managed to get 530 Km from a tank of E70 filled to the neck and run till it started to lean out . This isn't too far short of the best I did on splash blend E42 .
I'm planning to get the ID850GM injectors happening in about three weeks depending on when my tuners shop comes back on line .
I'm very keen to see how much of a difference modern injectors make to drivability and consumption . No one I know has ever got brilliant consumption out of a 33 era RB25DET but 'd like to see what's possible . Realistically GTT head rods and pistons is probably way to go .
52T still doing a good job , cheers A .
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
