Just had car fully checked and everything seems fine from spark to fuel.
Until I checked to see my power fc inside and looked like this.
Car is still hunting bad on idle and wont drive past 2500/3000rpm and runs pretty horrible with no power.
Most likely this is the cause as have changed just about everything.
Would anyone let me borrow for 5 minutes there power fc to test so I no for sure it is the problem, but I guess it still needs replacing by the looks of it lol
What do you guys think.
https://imageshack.com/i/f1q4wgj
https://imageshack.com/i/5s7ygfj
Holy Shit, I'm suprised it's driveable at all
Yes I'd say that is your problem. Do you recall anything that may have done this (bridging plugs etc)? Probably just the Power FC crying enough over age but if it could be something that has caused it on your car, then you need to fix that before replacing the ECU or it will happen again
I bought it few years ago and it had water in it and didn't no much then and as when I hooked it up it made a choooof sound and smoke came out and didn't make much of it back then so really forgot about it.
It ran ok till now but I just bought a adaptronic ecu all hooked up with a tune in it similar to my set up and still done it and I found the problem injector 5.
As soon as I disconnect it does nothing in engine sound at this point as all other injectors are fine as they change the engine sound when I disconnect the plugs from them,but sometimes it might start working but for now that's it.
Must be cause I ran the injectors real hard on e85 pushing 330rkw and think there 550cc.
Either blocked or leaking injector 5 but there's really nothing more but that as I changed every thing and this problem got worse after e85.
Still needed to change the ecu no matter Wat the outcome was as that PFC was ftt up and guy ripped me off which was not nice for $900
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
