currently building one using the 300k+ block that's already in the car ( seems to be in perfect condition surprisingly so have all my 30's other then one having f**ked vss ) and if i'm feeling adventurous highly unlikely though as i am a lazy flamin mongrel who hates to lay on the floor other then to sleep, the sump will be coming off to throw some bearings in it and to bump up the oil pressure up (lack of driveway).
almost together and consists of
gt35/40 cheapie on a decent high mount and external gate
3.5' superdragger i think
ebay plenum
660cc injectors
decent cooler 2.5" piping
z32 afm ( thinking about going the r35 route thoughts ? )
decent cooler
stock 25det head tidied up and modified for vct
arp studs
stock head gasket not genuine nissan
hdi boost controller
twin tensioners side by side
ebay oil cooler
external bosch 044 with surge
alloy rad
genuine nissan thermostat
cheapie catch can to do the catching
mx7/33box with 4 puck clutch
thinking about limiting it to 6.5 k rpm with the 300k old bearings and stock oil pump or around the 7 mark if i can be arsed to change the bearings.
hoping to pound it with 20psi and am hoping for just over the 300 mark, thoughts ?
ebay plenum
660cc injectors
decent cooler
arp studs
ebay oil cooler
alloy rad
Sounds ok I have 314 awkw with stock unbalanced bottom end but with rings, bearings and conrod bolts limited to 7000rev/min and 1.5bar. If you don't do the bearings limit it to 6000 - 6500 and it should make near enough the same power.
Kiwi rs4t that sounds like exactly what i'm hoping to do ! thanks, i have been waiting for thread like this to come up haha.
Superben, Surprisingly the motor looks brand new, the car has been serviced at a max interval of 7,000km's since new and everything that can be seen looks great.
Mine is a completely untouched low km bottom end bolted to a untouched head.
Rev limited to 6500rpm and 20psi putting just over 350rwkw. Only ever gets driven hard too.
Got some blow by at wtac, but that may have been from bouncing of the limiter all the down the main straight.
Cylinder psi is 130 across all 6 but im not sure I check correctly either.
Edit. Does has a 25 oil pump
i just pulled apart my next rb30. has pistons with 67s20 on the top. can anyone confirm if there genuine nissan rebuild ones? the part number on the pistons is the last numbers of the nissan rings but cant find part number as pistons
hopefully they are nissan ones. rebuilt between 100000 and 205000km somewhere
I'm not familiar with stock rb30 pistons, but stock rb26 pistons have 05U and a dot indicating front. So if 67S20 is the end of a Nissan part number it seems likely they are standard. And therefore standard bore as well which is good
  • 7 months later...
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
