As the title suggests I have a R33 Nissan Skyline Series 1 R33 Gts-t
The car has been sitting for a long time and now I get it running again there's a god aweful deap sounding rattle/Whine coming from where the exhaust cams CAS is.
I know this has been brought us SOOOO many times before and I have read something like 30-40 posts about the issue and there is a lot of sudgestions but not 1 had a result.
Well a helpful one anyway.
There are a lot of ideas on what it MIGHT be but it's like no one ever gets the issue sorted.
At first it sounds like the timing cover is rubbing NOPE.
People have suggested timing belt NOPE
Idler pullies guides and so on NOPE
This is a link to a vid of my noise
https://www.sau.com.au/forums/topic/440271-r33-rb25det-casexhaust-timing-noise/
Do you have a spare CAS? I had problems with mine ages ago when I did the timing belt. Didnt make a noise with the timing cover off but did with it on. For ages I thought it was just the timing cover vibrating. Turned out to be the CAS. I pulled it off and it was really hard to turn it by hand. So maybe pull it off and feel if the bearing feels rough/hard to turn
I thought that it might be throwing the bearing inside the CAS unit but it was a mongrel to remove but when I did it was spinning really freely. Flick it in between my 2 fingers like I'm trying to click my fingers and it spins. Make a little bit of a wierd noise thou.
I will try using the one off if my mates R33 S2!and see how that goes.
I will keep you posted
Do you have the washers for the CAS seal in there? They are needed or you will have CAS issues. The seal for the CAS sits in the timing cover and has 3 thick washers with groves in them fro the seal to sit in
Just remember that without these washers you can have issues
  • Like 1
Just an update.
The noise for some reason is different in the vid.
The noise is there at idle and stays there till around 1500rpm then disappears to where it is barely noticeable. But comes back when it returned back to idle.
  • 1 month later...
did you check if the washers are there?
I've asked the same question twice........
The thick washers NEED to be there.
Did you replace it with a new or a second hand CAS? If its second hand, whos to say it isnt semi stuffed as well?
Bit of an up date.
I called Nissan and the bloke told me that when new or working properly there is supposed to be SOME resistance when it is turned by Hand. To little and it's buggered. To much and it's buggered.
I swapped CAS with one off if a friends car that I know worked good and has no noise.
But no difference.
But I replaced it anyway. And the noise has died down.
Now I have a new issue.
The engine sounds like it's missing.
I have replaced the plugs. New spill fire coils.
But no change. Gunna start a new post about it.
I wont even bother anymore. Myself and at least one other person have told you what the problem most likely is. And you continue to ignore it. I cant be bothered anymore with people that don't read/listen
Some resistance. That's funny.
Ignoring the correct and sensible advice is even funnier. Let us know when this case starts making noise.
And I have to ask, with all this messing with the cas,did you set the timing correctly each time?
I have tried everything you guys have suggested.
AND NOTHING HAS WORKED.
Also you do not have to recalibrate your timing every time you remove your CAS Nissan said as I asked the question. They said NO because of the way the Keyway is set up and the toothing of the shaft it can only go on one way.
I'm sorry for not spending every minute on here but if I did how would I be able to try what people suggest.
I'm the one having issues and getting a handful of suggestions (That I do appreciate ) and I'm the one that has try physically do what you suggest. But if your going to act like a phsycotic wives carrying on because I don't answer your text right away then please don't bother posting.
Well that's just wrong. Have you noticed the massive slots the cas bolts go through?
Nissan don't give a shit about you or your car. They want to sell and service new cars,not help guys with old cars. You are wasting their time calling them,and that is reflected by their advice given to you.
If you think you line it up that good by eye good luck to you. You are lucky you havn't pinged the engine to death yet.
And finally, pull your head in bud, take a little time to show some respect to the people who are helping you out. The same question was asked multiple times and you didn't answer it, that's your fault for not mentioning you tried it (which I am assuming).
As above, its pretty obvioust that you do need to check timing every time you remove and re-install the CAS. You can mark the CAS and timing cover and try and bolt it up tight in the same spot, but it may not be 100%
And seriously, get over yourself. I tried to help you, and I think if you look back you will find my first 2 posts were as helpful as I could be with the information I had. It was because I asked you about the spacers/washers behind the CAS 3 times with no response (And you still havent actually said that you have checked they are there)
So I will explain to you why they are important. If they are not there, the CAS bottoms out and pushes the shaft etc into the bearings, causing extra wear which will lead ot bearing failure and NOISE.
Touch cas, re time
Loosen a few bolts, retime
Marked out cas place in same spot, retime
Replaced cas, retime
Do anything to cas, retime
Running aftermarket ecu? Lock timing and retime
And yes, listen to jiffo - he knows more than Nissan
I have checked the washers and there there.
I have also checked the clearances between the CAS and the cam it's self and with the 2 gaskets and washers Inplace I have 2.5mm clearance.
I do agree with you saying maybe the second hand one could be buggered aswell.
I have been told of a place that can just replace the bearing.
I have put up an update to this post aswell
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
